dash lighting problem with 2001 pt cruiser
Old 08 May 2015, 08:02 pm
Default dash lighting problem with 2001 pt cruiser
At night the dash lights are bright and can be adjusted by the dimmer. during day they are nonexistent. Is there a sensor that tells the car if it is day or night and if so how can I replace it or disable it.
Old 08 May 2015, 08:13 pm
soonercruiser's Avatar
Cool Re: dash lighting problem with 2001 pt cruiser
Nope!
I believe that you've got the problem all wrong.
On the Gen 1 Cruisers, the bulbs and instrument cluster display is very dim; as compared to the 2006 and up. They are especially troublesome at dusk.
You need to pull the instrument cluster and replace the bulbs with #2723s, or LEDs.
See the historical threads in the "Interior Forums", as well as this one and "Tech Forum".
Frank, aka SOONERCRUISER,
Old 08 May 2015, 08:26 pm
Default Re: dash lighting problem with 2001 pt cruiser
Hi thanks for your reply. the bulbs were replaced two days ago. I don't think I have the problem wrong the lights are very bright at night and not on during the day
Old 08 May 2015, 08:33 pm
LionPT's Avatar
They are only on when the headlights are on.
Why do you want them on in the daylight..??
Old 13 May 2015, 06:42 pm
thanks for your reply. the reason I want them on in the daylight is because the gauges are recessed and unless the sun is directly on them they are can't be seen.
LED under dash lighting? saraveza408 Interior Accessories Forum 4 30 Jan 2016 12:04 am
08 Cruiser general dash lighting BigMack General PT Cruiser Discussions 2 04 Apr 2015 12:14 am
Dash lighting problems sticky maybe? woodsman Feedback and Support 3 28 Feb 2015 10:43 pm
Question about dash lighting. IamN00bz General PT Cruiser Discussions 8 13 Mar 2012 12:26 pm
dash/speedometer lighting tomctomc General PT Cruiser Discussions 7 09 Dec 2005 11:44 am
