PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   General PT Cruiser Discussions (http://www.ptcruiserlinks.com/forum/general-pt-cruiser-discussions/)
-   -   Air Conditioning (http://www.ptcruiserlinks.com/forum/general-pt-cruiser-discussions/56777-air-conditioning.html)
bleed_grey 19 May 2015 07:39 pm
Air Conditioning
I have a 2006 Cruiser Touring Edition. Just a bit ago I went to recharge the air conditioner. Then when I went to fill the car with the coolant a sort spraying noise happen twice from underneath the car, it was kind of loud. I've refilled a few different car in the past but never had this problem before. Has anyone had this happen? If so what was the fix?
ptcruisersteve 19 May 2015 07:44 pm
Re: Air Conditioning
What was the reason for recharging the A/C? and how much freon did you put in it?
bleed_grey 19 May 2015 07:51 pm
The a/c was blowing out semi-cool air more so warm, so from my past experiences I figured my cruiser needed freon. Just a one squeeze of the trigger and then the spraying noise. The noise happen twice.
CREWZIN 19 May 2015 08:10 pm
There's a discharge valve on the underside of the compressor. When the compressor is overheated or has too much R134A, the valve opens and the freon is released with a loud hiss and white smoke.
http://img.photobucket.com/albums/v7...C00002%202.jpg
bleed_grey 19 May 2015 08:12 pm
Yes! Bingo. Would that keep my compressor from kicking in?
ptcruisersteve 19 May 2015 08:29 pm
i would suggest checking your radiator fan. When the engine is cold and you first start it up and turn on the A/C does the radiator fan turn on automatically.
bleed_grey 19 May 2015 08:32 pm
Is this a DIY fix or would I need a repair?
