oil pressure switch 06 basic non turbo
Old 20 May 2015, 03:10 pm
Default oil pressure switch 06 basic non turbo
What is the best way to replace the oil pressure switch. Does not look like there is any room for my fat fingers?
Old 21 May 2015, 07:02 am
Default Re: oil pressure switch 06 basic non turbo
A deepwell socket it is like an 1" and a 16" remove plug (move little red tab to release) even with a deepwell socket a short extension may help. I replaced mine because I had an intermittent oil light coming on in morning first start "Bing" shut off engine restart no light just a little annoying ...No problems since I replaced the switch.
Old 21 May 2015, 08:00 am
Thanks, but I know the easy part. How do you get to it and what do you remove if anything to get access. Searching the web anywhere from taking out the axle to only removing a bolt to wire bracket from underneath??
Old 21 May 2015, 11:06 am
Because Trump
Old 21 May 2015, 01:28 pm
Should have told you remove air box, the switch is located on back left side of the block . With an inspection mirror and a flashlight you can see it clearly. You probably will have to go by feel more than sight as I did ,you can really only reach it from the top from the bottom the frame crossmember and axle half shafts block you from getting to it .The Haynes manual shows pictures and the R&R .
Old 22 May 2015, 10:42 am
Thanks all.
Old 10 Jun 2015, 02:31 pm
oil pressure switch 1 me 0
Attempted to replace the switch. Removed the airbox and moved the TIMP.
The shift cables are definitely in the way and tried to remove them. Can't get the spring clip off, any ideas? No place for leverage don't want to break anything. Going to look for right angle needle nose pliers maybe that will help??
Old 10 Jun 2015, 04:30 pm
hey man! -try my method: HOW TO: oil pressure sensor replacement
sorry in advance
Old 10 Jun 2015, 06:39 pm
to remove my shift cable clips i put a vise grip on the edge of the clip and tapped the vise grips with a hammer. once it's off a bit you can get a flathead in the opening of the clip's U shape.
Old 11 Jun 2015, 08:00 am
I'm sure there is a car out there you have to do that! Was watching a vid the other day the guy was changing knock sensor in a Chevy. Had to take the intake off, what a job! KNOCK SENSOR 3hr, 5 min job. What is this world coming toooooooo!
I will try the vise grips and whatever other tool I can find. Also looks like the red part of the clip will be fun at that angle as well.
[How To] Change the Oil Pressure Sending Unit/Switch on 2005 2.4L Turbo PT Cruiser ingram87 Tech & Performance Forum 2 02 Aug 2014 06:14 pm
2003 gt turbo oil pressure switch ladycruiser General Turbo Discussions 1 07 May 2014 09:09 pm
Putting a turbo on a basic model Jhardwick Tech & Performance Forum 26 17 Mar 2014 06:29 pm
basic mainteance and.....where is the oil pressure swtich? srebik Tech & Performance Forum 3 10 Mar 2011 12:05 pm
Good Links for Basic Turbo Tech_ FAQ's_Myths Steve03GT Turbo Performance 3 05 Jun 2003 01:55 pm
