Radio problems
Old 23 May 2015, 04:44 am
Default Radio problems
Hi all :-)
I recently had the ignition switch replaced on my 2003 Cruiser (the mechanical one).
When the car was fixed, I lost the use of my radio. It doesn't have any power going to it with the key in the ignition. I found though that if you push the key in a little further and turn a tiny bit, the power comes back on and it's asking for the code (which I don't have).
Any suggestions on how to fix my radio? I have a 3 hour drive coming up in 2 weeks and I need my music!
Thanks in advance!
Old 23 May 2015, 06:33 am
Default Re: Radio problems
We don't have/need the radio code here in the U.S. Here are some older threads talking about the code that you need. Maybe one of them will help. The last one is a site that has a UK link to click on. There you will enter the serial number of your radio so you can enter it on a form and retrieve your radio code.
lost radio code
radio code
Mopar radio security code.
Chrysler PT Cruiser - Radio code number : Motoring Motoring Discussion forum
Welcome to the forum.
Old 23 May 2015, 07:32 am
Thank you for your help (Aand the welcome)
Do you know how I can resolve the key / power issue I have as well?
Old 23 May 2015, 07:36 am
All I can say about that is that the ignition switch itself might be to blame or if you have too many objects on your key ring, it might be pulling on the key. Try using just the one ignition key itself and see if that helps.
2001 radio problems murr Sound and Security Forum 4 18 Mar 2015 10:53 am
Radio display problems ThePTCrusader General PT Cruiser Discussions 20 17 Sep 2014 03:40 pm
2003 radio problems defflepp1 Sound and Security Forum 2 08 Feb 2009 11:31 pm
radio problems ds1950 Sound and Security Forum 3 10 Aug 2003 07:00 pm
