Weird overheating problem
  • 1 Post By NitroPT
Old 23 May 2015, 03:21 pm
Default Weird overheating problem
2006 touring
After driving for a mile or so, it starts to overheat, I stop the car, check the fan and radiator, the fan is fine.
The weird thing is the radiator hose. The upper radiator hose has pressure built in it, but it is cold. I thought the coolant in the engine was not circulated into the radiator upper hose yet. But how could this happen, if the pressure inside has been built up?
Then I continue to drive it, the gauge drop to normal level, and the upper hose became hot, which make sense.
What confuse me is, if this is a thermostat problem, why there is pressure built up in the upper hose but the coolant there is cold?
Old 23 May 2015, 04:23 pm
Default Re: Weird overheating problem
I would suggest you check your thermostat and see if its not opening up.
Take a infrared non-contact temperature gun and see what the temperature difference is between the upper and lower radiator hose.
Old 25 May 2015, 06:18 pm
Thanks
I think it is the thermostat.
The temp gauge passed the mid-level a little, then returned to normal level.
I guess the thermostat open a little later than designed.
I did replace the original one with a stant superstat because the original one was leaking.
Should I replace the thermostat again? which brand is better?
Thanks
Old 25 May 2015, 06:34 pm
What temperature stant superstat did you put in it?
How long ago was this thermostat replaced?
Old 25 May 2015, 06:39 pm
LionPT's Avatar
Originally Posted by postbeauty View Post
Thanks
Thanks
This is also the spot when the fan will kick in.
Old 25 May 2015, 06:54 pm
2006 touring
When you say it starts to overheat how far did it go up to on the temperature gauge?
Old 26 May 2015, 10:59 pm
I used the superstat 45209, it is 195F.
I replaced it in the winter.
Old 26 May 2015, 11:00 pm
Yes, the fan starts to work.
But the issue is the hot coolant is not circulated into the radiator, so the fan can do nothing.
Old 26 May 2015, 11:02 pm
If the mid-level is normal level, and it is 50% of the range,
Sometimes it can go to 75% of the range, then drop to the 50% level.
Before that , the upper hose is cool.
Does this hurt the engine?
I really do not want to replace the thermostat again.
Thanks
Old 26 May 2015, 11:48 pm
The STANT Super stant is one of the best thermostat you can get. It work beeter than the OE dinasure type thermostat and better then most all aftermarket replacements. Your discription sounds like it is working properly.
It you go to STANT and resd how they work you will understand better.
You may want to consider what Steve is suggestion as far as tempreture varification is concerned. After all the gauge is controled by the senor and it value may be incorrect which would need you to replace the sensor.
Your last response is more inline with air flow which means fan related or radiator.
HELP ASAP! weird Overheating problem 2001 PT ptptptpt Tech & Performance Forum 20 20 Dec 2015 10:14 pm
Grrrr!!! Weird overheating. GrapeApe Tech & Performance Forum 6 03 Feb 2015 03:07 pm
overheating weird problem... nor11384 Tech & Performance Forum 37 02 May 2013 07:35 pm
02 PT Cruiser Overheating (Very Weird issue) HDuece2 General PT Cruiser Discussions 19 12 Feb 2011 10:22 pm
Weird Problem JoeyC33 General PT Cruiser Discussions 5 06 Aug 2008 05:21 pm
