A/C Fan and Powered Windows go out at the same time
  • 1 Post By sanatanadharma
Old 25 May 2015, 03:31 pm
Default A/C Fan and Powered Windows go out at the same time
Hello everybody,
So I've had this problem for about a year now. My fan for my ac and my powered Windows will go out on the vehicle at the exact same time. They've came back once and then off again. I've checked all fuses and changed the electrical part of my ignition switch and still no results. No one can tell me what is going on and I have a son on the way and can not use the car without the ac. Please if anyone has any clue on what's going on it would be amazing for you to share. It's a 2002 pt
Old 25 May 2015, 03:44 pm
Default Re: A/C Fan and Powered Windows go out at the same time
Welcome to the forum.
The power windows for the 2002 and later PT's are all powered by the Circuit Breaker No#2 in the fuse box in the interior of the car by the drivers left knee. The A/C fan uses a couple different fuses from the interior fuse block and the Power Distribution Center in the engine compartment. Why the two separate systems would go out at the same time doesn't make sense. However the IOD fuse in the PDC does control several different functions on the PT. Did you check to see if the IOD fuse is good? Maybe someone else can give you some more help.
Are they the only two things that stop working at the same time. Did you try other accessories and functions to see if there's more that goes out?
Old 25 May 2015, 04:21 pm
LionPT's Avatar
Check the plug behind the inside fuse box...it has been known to melt.
Old 25 May 2015, 05:39 pm
Because Trump
CREWZIN likes this.
Tags
air, fan, windows
Viper powered PT Atrus1212 General PT Cruiser Discussions 3 17 Oct 2009 10:12 am
Battery powered Outlet port jimmirehman Interior Accessories Forum 17 12 Jul 2007 08:24 pm
Kenwood powered subwoofer BLH1 Sound and Security Forum 3 08 Apr 2004 03:39 pm
powered sub woffer kgdptblue Sound and Security Forum 27 01 Jul 2003 12:37 am
