How to get power window down in junkyard to remove it?
Like Tree5Likes
  • 3 Post By Handy_Cruiser
  • 1 Post By Handy_Cruiser
  • 1 Post By soonercruiser
Old 27 May 2015, 01:56 pm
Default How to get power window down in junkyard to remove it?
Came out to find my vehicle broken into. Main issue for me is the fact that these are probably all power window models? Even if not I will have to deal with whatever is in the junkyard.
Can't take batteries into the yard and can't rely on the vehicle to provide power directly even with a battery. Someone mentioned using the 18v battery off my drill which I'll have on me anyways. Does anyone have an idea what that harness is like? Passenger side front window.
Old 27 May 2015, 02:47 pm
Handy_Cruiser's Avatar
Default Re: How to get power window down in junkyard to remove it?
I've removed PT windows in a salvage yard. You do not have to lower them with the regulator.
Instead it is fastest to just take the regulator loose from the door and from the glass and remove it. Then the glass will just slide down. Take the track loose, turn the glass at an angle and pull it out.
PS: The harder job at the salvage yard is often just to get the doors open on a PT. When some folks remove the door lock pull knobs, they inevitably push the door lock rod down when they screw the knobs off. So the doors are locked and the rods are down inside the doors. I often have to go in throw the back hatch. Then I climb over the seats and take a piece of a wire coat hanger shaped so I can reach through the pull knob holes and get a hold of the rods and pull them up. That's hard. And it's especially hard when it is over 100 degrees in the salvage yard and I am in a PT with the doors locked and all the windows up. Plus if I'm not careful, the rear hatch will close due to weak or missing lift struts, and I am effectively locked inside the PT "oven" until I can get one of the doors open. Fun, fun and more fun.
Old 27 May 2015, 02:49 pm
Is it bolted in or glued in I just saw some replacement glass with no hardware on it.
Old 27 May 2015, 02:56 pm
It's all bolted. The regulator is even bolted to the glass. I believe you can do the hole job with a ratchet, 7 mm socket, 8 mm socket, 10 mm socket, needle nose pliers, and some various screwdrivers and/or prying tools. A few socket extensions and universal joint adapter come in handy too.
buddyiramae likes this.
Old 27 May 2015, 03:24 pm
soonercruiser's Avatar
Cool Re: How to get power window down in junkyard to remove it?
That was my first thought.
If you are going to take the door apart to get a window/regulator, you should be removing everything that holds it in place anyway.
If it were me, I'd take the whole "works".
I now have no extra parts in the attic. "All" has either been given away or sold!
That's how it should be.
Handy_Cruiser likes this.
Frank, aka SOONERCRUISER,
Old 27 May 2015, 04:00 pm
I just want the window. On GM you just roll the window down unbolt it since the bolt hole openings are at the bottom of the door and lift the window out. Getting the regulator out would require drilling out rivets. So on GM I know its simple. 5 minutes I can get the window out of a sunfire for example. You guys make it out like taking the window out of a PT is harder lol.
Old 29 May 2015, 07:36 pm
VNT's Avatar
VNT VNT is offline
Remove the interior door trim, will have to unbolt the regulator and about 4 bolts which hold the glass in regulator channels, be damn careful because there is a lot of sharp edges on the sheet metal and what not, I sliced myself good pilfering a cruiser for the regulators.
once you get the regulator out, you should be able to remove the glass.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 30 May 2015, 04:37 pm
To remove the door panels, first remove the triangle trim at the rear view mirror. No need to remove door lock knobs, leave them on.
The use a Phillips head screwdriver and remove the screw inside the door handle opening and around the edges of the door panel where you see cutouts.
The using the appropriate size Torx bit remove the two screws holding the arm rest to the door.
Now pull back on the edge of the panel give a sharp pull outward. This will pop loose a couple of the six or eight bullets that hold the panel to the door. Move around the panel down across the bottom and up pulling the panel free.
Now hold the arm rest and the front edge of the panel and pull upward slightly to free the top of the panel and lift it off the lock knob.
Once free it will pull out six inches or so so you can unhook the door lock wire plug and pop the latch off the door handle rod and pull it free.
Now set the door panel aside and get to work, nothing bent, nothing broken. Reverse steps to install.
Junkyard Cruisers mopar_man Classifieds: For Sale/Trade 28 13 Aug 2013 08:11 pm
How to remove rear window controls? Flot General PT Cruiser Discussions 4 20 Jun 2008 06:11 pm
How to remove front power windows switch...? whitbyPT Tech & Performance Forum 2 20 Feb 2008 04:59 pm
Remove turbo silencers = more power??? Gary04GT Turbo Performance 3 12 Apr 2004 11:32 pm
remove power outlet plug ??? Jimbo Interior Accessories Forum 3 28 Feb 2004 07:20 pm
