tie rod/alignment question
Old 31 May 2015, 01:41 pm
Default tie rod/alignment question
About two months ago I got two front tires for my 2010 Cruiser with 66,000 on the clock. They had worn unevenly. About a week later I had an alignment. The last several days there has been a noticeable shimmy when I get close to 50. Now, about two weeks ago when the car was getting state inspected I had to have a motor mount replaced as well as a tie rod end. So, my question is, do I need to have another alignment due to the tie rod replacement? My back tires are cupped and I have to get other ones this week if I can find the time. Possibly, the shimmy is coming from that.
Old 31 May 2015, 01:58 pm
Handy_Cruiser's Avatar
Default Re: tie rod/alignment question
Yes. If you have had a tie rod replaced, then you definitely need an alignment or at least have the alignment checked.
Also, I recommend you go some place new for the alignment. A good shop will do a pretty thorough inspection of the steering and under carriage while doing the alignment. If you picked up a shimmy right after the last alignment, either something came loose, the shop did not find an existing problem and/or they did a poor or incomplete alignment. It may not be their fault, but why take the chance?
I prefer doing most automotive work myself. But it really takes a good tech with the right equipment to do a proper alignment. And the inspection they do while the car is up on the lift is very valuable to a DIY guy since some issues are much easier to detect once the car is in the air. This is money well spent.
Old 31 May 2015, 05:52 pm
Actually, I think it might have been a tie rod end. If my recollection is correct, does that make any difference?
Alignment question Shiniquiet Wheels, Tires, Suspension 6 24 Jul 2014 07:30 am
rear hatch alignment question sharpeel General PT Cruiser Discussions 1 28 Aug 2011 02:18 pm
re: Timing Belt Alignment Question SteveG22 Tech & Performance Forum 1 13 Jan 2011 02:43 pm
Alignment necessary??? Shiniquiet Wheels, Tires, Suspension 5 28 Jul 2009 05:11 am
04 PT GT Alignment Kit biggus127 Wheels, Tires, Suspension 5 24 Oct 2008 07:37 pm
