Instrument Gauges Go Dead, Then Power loss
Like Tree4Likes
  • 2 Post By ptcruisersteve
  • 1 Post By 06OregonCruiser
  • 1 Post By wb2kki
Old 07 Jun 2015, 09:50 pm
Default Instrument Gauges Go Dead, Then Power loss
2006 PT Cruiser Base Model:
The past couple of months, on occasion, while driving down the road, the Instrument Panel Gauges would all go dead and all of the indicator lights would come on. Than, the car would lose power for a few seconds and come back.
It has grown more and more and tonight, it actually died but restarted. The battery was just changed 6 months ago. I've looked up the issue and it appears to be a very common one that has never been solved nor recognized by Chrysler.
When I bought the car the new in 06, from the start it displayed electrical issues that I complained about and took in several times, only for the dealership unable to replicate the issue. Since then, I've lost my AC, which a Mechanic said it was an electrical problem, my Head lights flicker when turning on or switching from low to high beams.
But the main issue now is the Instrument panel and loss of power. Can anyone help? I've read it could be; PCM, BCM, CAN bus, (Controllers Area Network), a defective alternator, and countless other possibilities. Any and all help would be extremely great! Thank You
Last edited by Triplesevn; 07 Jun 2015 at 09:56 pm. Reason: Added Year & Make of Car
Old 07 Jun 2015, 09:55 pm
Default Re: Instrument Gauges Go Dead, Then Power loss
The Problem
Old 08 Jun 2015, 12:07 am
I would suggest checking your ignition switch if the engine is cutting out when you have the dancing gauges but first make sure all battery cable connectors are clean and making good contact. Make absolutely sure your battery is good before checking the ignition switch.
Alynn and Triplesevn like this.
Old 08 Jun 2015, 05:11 am
2006 is the first year of the can-bus system. I have heard that the TIPM can cause all kinds of electrical issues. I don't know how to prove if it's good or bad. Good luck.
Triplesevn likes this.
'06 Cruiser Touring, 157k, Cool Vanilla, Auto
Old 08 Jun 2015, 05:55 am
Electronics are a nightmare as you see so it can be anything . But where I wound start is with the TIMP. Other than the computer TIMP is the heart other than the battery. First double check the battery connections and grounds. Then take apart the TIMP and clean the terminals bunch of connectors on the bottom and check for water damage. Pull the wire harness connections check for water. Other than that you have to wait till it goes haywire find a guy who can really read a dealer scanner.
Been having problems for two years with my Liberty getting all kinds of alarms and the car going into lip mode. Lucked out and found corrosion in a 73 pin connector. Dealer and my mechanic could never find the problem.
Good luck.
Old 15 Jun 2015, 06:37 am
Thank You all for the help. I just incurred another issue as well. My brakes went hard and the engine rpms were up. Thanks to this forum, I found the problem.
Vaccum valve rubber stopper appears to have come off. You could hear the hissing sound coming from it. I put electrical tape over it since none of the mass auto parts stores had a rubber stopper big enough to fix the problem. I'll contact my local dealer and see if I can get the replacement from them today.
Otherwise, I haven't had the issue with the dash since plugging that. I wonder if that vaccum plug missing had anything to do with the Dash. I think it's about time to get rid of my PT. I've had it since day 1. Bought it in March of 07 (it's an 06) and it now has 210 TM on it. I've had to replace the engine thanks to a blown belt. It's been in 5 wrecks, none of which were caused by our PT. And of course the typipcal upkeep, wear and tear maintence stuff.
Thanks again for the help...
Tags
electrical problems, instrument cluster, instrument panel, power loss
Instrument cluster flashes and gauges drop mbaker115 Tech & Performance Forum 14 10 Jul 2013 07:33 pm
Instrument Cluster Dead & No Start nickcruiser Tech & Performance Forum 2 28 Jan 2013 02:25 pm
Instrument cluster goes dead kwells44 Tech & Performance Forum 5 02 Dec 2012 06:08 pm
Dead Instrument Cluster JohnBrehm General PT Cruiser Discussions 0 09 Jan 2011 10:16 pm
Whole dash dead, gauges & interior light HELP ! c13ckb Tech & Performance Forum 0 17 Jan 2010 01:16 pm
