Wiper Low speeds problem
Old 09 Jun 2015, 09:45 am
Default Wiper Low speeds problem
Hello guys! its me again. Day by day I'm repairing my pt 2006 with love hahaha
I have this rare problem that I found this rainy day.
If I put the wiper on any intermittent speed will just work the first time (when I change the position) and then will no longer move until I change it to any other position. When I put on the static speed will work without problem (the medium and the high speed). I think that is something related to a relay may be?
Any thought where I can look?
thanks for the time!
Old 13 Jun 2015, 06:24 pm
Default Re: Wiper Low speeds problem
Its like my 4th post of different subject and no reply :'(
Guess my problems are super complicated or Im not very welcome here
Old 13 Jun 2015, 06:50 pm
LionPT's Avatar
Sounds like it's the MFS to me...the wiper side needs to be replaced if you want it to work.
I had the same problem with my rear wiper, it not longer works but everything else is fine. I'm not going to replace until front wipers start to act up.
Old 13 Jun 2015, 08:39 pm
RickinPA's Avatar
I'd agree with LionPT.
A wiper system has some interesting design elements. There's a "park switch" in the wiper motor that senses when the wipers are in the park position. When you turn the wiper switch off, the "park switch" keeps the wiper motor running until the wipers are in the park position, then the "park switch" shuts off the wiper motor.
For continuous operation, the wiper switch applies power to either a low speed winding in the wiper motor or a high speed winding.
For intermittent operation there's a timer circuit that just applies a short pulse to start the wiper motor. Once the wipers have started, the "park switch" keeps the wipers operating one full cycle. The duration between pulses is controlled by the delay knob on the end of the wiper switch. According to the service manual the delay between pulses can be set between once a second (minimum) and once every 18 seconds (maximum). I think your problem is in this circuit. It sends out the first pulse when turned on, but doesn't generate any more pulses after the first one.
My service manual indicates that all electronics (including the intermittent timer) and relay are inside the switch assembly. It also indicates problems with the intermittent function are either the switch or a wiring problem, and I'd suspect it would be the switch. NOTE: My service manual is for the 2001 PT Cruiser. It appears there was a redesign in the wiper switch between the '05 and '06 model years. On the bright side, the newer switches appear to be less expensive than the earlier switches.
Tags
intermittent, problem, wiper
rear wiper grommet size problem gooberff General PT Cruiser Discussions 2 08 Oct 2015 05:05 pm
Over heating problem at highway speeds... 1911ly Tech & Performance Forum 7 15 Sep 2015 08:15 pm
2006 cruiser rear wiper problem wherley Tech & Performance Forum 6 30 Jul 2012 11:02 pm
wiper problem bhunt41 Tech & Performance Forum 11 25 Jul 2011 10:29 pm
rear wiper problem rrgsj Tech & Performance Forum 4 21 Mar 2009 07:32 pm
