what's inside that radiator?
Like Tree8Likes
  • 7 Post By RickinPA
  • 1 Post By rob342
Old 13 Jun 2015, 05:23 pm
RickinPA's Avatar
Default what's inside that radiator?
I had to replace the radiator on my '01 PT. It had corrosion on the upper seam and was starting to weep coolant. It had 120K miles on it and the cooling system was reasonably maintained. The OEM radiator was a Valeo, made in Mexico.
I ended up taking the old radiator apart in preparation to scrap it and took some pics:
Here's an overall picture. The plastic tank ends are held in place with the little crimped aluminum fingers. There's a rubber gasket between the tank and radiator to keep things sealed.
I was wondering how much force is trying to part the tank end from the radiator, a simple calculation:
1.6" x 20.3" x 16 psi = 520 pounds
Yes, the force on the tank end at operating pressure is 520 pounds.
How much force is on each little aluminum finger? There's 116 little fingers, so:
520 lb / 116 fingers = 4.5 pounds per finger
Here's a close-up of the tubes. I was a little surprised how elongated they are. None of the tubes was plugged, there was just a little bit of debris in a few of the tubes on the inlet side. The inlets on each tube have a slight flare that reduces inlet restriction and helps coolant flow.
Just thought I'd share.
Old 13 Jun 2015, 05:30 pm
Default Re: what's inside that radiator?
here's the inside when i cracked mine open at 249k miles (:
anybody try the $54 radiator
FYI - mine still cooled fine, but it was leaking at the crimp
NitroPT likes this.
Old 13 Jun 2015, 06:14 pm
"KOOL" pictures!
Old 14 Jun 2015, 06:50 pm
rcktpwrd's Avatar
Cool Re: what's inside that radiator?
interesting pics!
They use the flat wide tubes in radiators because there is much more surface area to dissipate the heat to the fins.
Joel
www.rcktpwrd.com
Old 14 Jun 2015, 10:56 pm
soonercruiser's Avatar
Talking Re: what's inside that radiator?
Originally Posted by rcktpwrd View Post
interesting pics!
Sooooo....
Your radiator job isn't complete until it's "finished"????
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Fumes inside Gub General PT Cruiser Discussions 6 03 Jul 2014 02:58 pm
Juicing the inside Duster Sound and Security Forum 9 16 Nov 2010 12:23 pm
Inside Paint Job she_so Interior Accessories Forum 5 19 Aug 2009 01:16 pm
Inside Top Liner grizhlr PT Cruiser Convertible Forum 3 11 Nov 2007 02:35 am
Inside badge Jimbo General PT Cruiser Discussions 1 08 Feb 2004 09:17 pm
