heater valve
Like Tree2Likes
  • 2 Post By Handy_Cruiser
Old 16 Jun 2015, 04:04 pm
Default heater valve
hi to all just got a cruiser 2 months ago not with out its problems but was wondering about the one way valve on the heater pipe as got engine out and took it off to find a small hole inside about 6mm the way it looks with arrow on the outside as if water can only go the one way as this looks like the only way for the water bypass till the thermostat opens
the other thing I wanted to ask was what kind off pressure would be in the cooling system after about 10min idling as fitted replacement engine took off rad cap and blew water up about 12 -14 inches
thanks
Old 16 Jun 2015, 06:20 pm
Handy_Cruiser's Avatar
Default Re: heater valve
I know not of this thing you call, "heater control valve". Where be this nefarious device on thy beloved PT Cruiser?
As for the pressure on the radiator. It should be exactly the same as printed on the radiator cap. And for 12 inches or so of fluid to gush out when removing the cap from a hot engine, unusual not that be.
heater hose variable valve? Alltorque1983 General PT Cruiser Discussions 12 20 Mar 2015 06:21 pm
Heater Scot Tech & Performance Forum 8 04 Dec 2014 12:48 pm
Heater/AC control billcreech Tech & Performance Forum 1 24 Jan 2014 11:46 am
Heater Aodoggie General PT Cruiser Discussions 7 27 Jan 2012 06:06 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
