engine code P2074
Old 17 Jun 2015, 09:01 am
Default engine code P2074
i have a2006 pt cruiser had cam sensor code changed it car ran good for 3 days started cutting out rpms only go to 3000 no power car wont do 10 MPH, code is P2074 checked Map sensor good, changed TPS sensor 2 new ones still doing same thing, TPS is suppose to put out 4.5 volts the old one and both new ones only put out 3.7 at full throttle does this matter all 3 bad don,t think so. searching it also lists the ECM Engine Control. module. has anyone had this issue ??? thanks in advance.
Old 17 Jun 2015, 09:36 am
LionPT's Avatar
Default Re: engine code P2074
Check for a vacuum leak.
Old 17 Jun 2015, 01:27 pm
make sure you have the TPS on right and recheck voltage before anything else. also verify the sensor ground wire is a good ground. you might also rotate the TPS with a flathead to see what reading you get when you turn it manually
see attached for correct installation, might be a really simple fix.
Old 17 Jun 2015, 01:33 pm
also if you read a bit on here you'll see aftermarket cam sensors are JUNK. some last a day, some last a week. its HIGHLY likely that the one you bought is bad already if it didnt come from the dealer
Old 17 Jun 2015, 02:11 pm
it got 12volts going into the plug, 4.5 volts going to the sensor,.69 volts at throttle when closed only goes to 3.69 volts wide open, when manually opened, book shows should be 4.5 volts, the old one and 2 aftermarket all read 3.69 full open, saw somewhere someone had these issues it was ECM module, there are no vacuum leaks.
Old 02 Feb 2016, 09:56 pm
Default Re: engine code P2074,,(Oil smoke exhaust)
Hey every one,,
Newbie to the PT Cruiser world.
I just picked up a 2006 convertible with the 2.4 Turbo engine.,
After doing a new owner maintenance checks.
Took it for a ride an found out it started ,idled, and ran great till I tried to step down on it.
3500 r.p.m. it bucked and skipped and the check engine light came on.
Went and got it checked and came back P2074 as you know MAP sensor.
Went to fuel up an the the blue/oil smoke came out the tail pipe.
Tried to get home,,it got worse NO power..
Is the turbo gone an are the TWO related to one another???
THANKS
Any Help Is A Help
Mike In Maine
Old 27 Sep 2016, 09:47 am
Do you have box OEM air filter or aftermarket one?
I have get ethis error and power done with K&N typhon filter
ERROR CODE P2074 spinner Tech & Performance Forum 5 30 Jul 2016 06:00 pm
P2074 & P0123 After replacing TPS & MAP Davejay General PT Cruiser Discussions 1 06 Sep 2013 05:30 pm
P2074 Error, Cause and Resolution mriggins General PT Cruiser Discussions 3 21 May 2013 07:20 am
code p2074 interrex General PT Cruiser Discussions 8 08 Sep 2011 03:37 pm
P2074 & P0122 Codes idiotsgod Tech & Performance Forum 6 16 Feb 2011 05:46 am
