Removal of Air Bag 2009--How to get the air bag retaining clip to release
Old 18 Jun 2015, 03:13 pm
Default Removal of Air Bag 2009--How to get the air bag retaining clip to release
I am (early) in the process to install a speed control in my 2009. However, I am stuck on the airbag retaining clip. I understand how it works. I have looked at pictures of a removed airbag and I can see up in the hole. I have several stubby flat blade screw drivers. I can feel the clip move as I twist the screw driver, but it will not release. Any tips or tricks to get the air bag off (0n a 2009)? Any insights would be greatly appreciated. Thanks.
Old 18 Jun 2015, 10:52 pm
Default Re: Removal of Air Bag 2009--How to get the air bag retaining clip to release
I was finally able to get the airbag connectors to release. I used the largest Craftsman semi-stubby flat tip screw driver that I have. It just barely fit in the hole and it was just large enough to get the connector over the catch (as the flat part of the screw driver was twisted 90 degrees) and thereby release. Also I had to have the steering column as low as possible to accommodate the longer screw driver.
Old 19 Jun 2015, 01:06 pm
soonercruiser's Avatar
Angry Re: Removal of Air Bag 2009--How to get the air bag retaining clip to release
EXACTLY!
There had been several posts on the tightness of the retaining clips in the last year on this forum.
I know that I will likely make several trips behind the dash in my PT's lifetime.
So, I simply flatten those clips to make them easier to release.
The engineers engineer fit and tighness.
They probably NEVER try to take off the parts they design.
DUH!
Frank, aka SOONERCRUISER,
Shift cable clip removal Jamesfb4 General PT Cruiser Discussions 0 09 Sep 2014 09:55 pm
wheel cover retaining nut ld626 General PT Cruiser Discussions 6 19 Aug 2012 09:33 pm
Give Me Some Release! (Deck Lid Release) GTCRUISER2006 General PT Cruiser Discussions 4 20 Feb 2012 12:30 am
cluster removal in 2009 PT??? cme_poopie Interior Accessories Forum 3 23 May 2010 06:24 am
The Cap Clip, gas cap solution! Got My PT Vendors & Buyers Forum 0 16 Mar 2002 03:39 am
