Ok so the stupid little plastic quick connect with the accumulator that connects to the metal incoming fuel line on the firewall is leaking. bought a new one. Still leaks. it has a flange for the connector to snap on to so u cant just cut it off and pop a new line on. at least not if you want to use the accumulator which I am not sure what it will do if u did bypass it yet. so I tried some gas resistant sealant but it still leaks. so now what do I do? not really enough room there to cut back and re-flange the metal tube which is the problem I am sure being I rebuilt my old one and it still leaks. new or old still leaks. So do you replace the whole metal line or bypass accumulator and put a real hose on it or what. I sure as hell hate the stupid plastic connector on the rail side where its on top of the motor. What the heck was they thinking!!! they should recall all that and fix it.... Before I just let it burn down what do I do...??? :{
kinda scary set-up isn't it... IIRC, there was a recall early on regarding fuel line abrasion but not sure if it directly related to your issue
maybe a real fuel system pro could re-plumb everything with high pressure hose, AN fittings, an aftermarket metal accumulator, etc. (btw, probably not wise to bypass the accumulator or damper as it is sometimes called as it functions to smooth out the fuel flow and also prevent vapor locking) anyway, there is a fire extinguisher on board my PT |
![]() Quote:
rubber fuel injection hose(the discount parts store type anyways) still expands a bit and if you use too much length you'll need to twist the key to prime it a couple times to build up pressure before it'll start. my neighbor did this and explained what he had done when i asked him why he was cycling the key before starting it. this was on a 40psi system with 48" of hardline replaced with fuel injection hose. with the 58psi pt system may be even worse. |
![]() Quote:
Another thread quotes the fuel supply item number as 5085555AC on a PT turbo? Does anybody know if it's the same item with 3 different numbers that have been changed during the years or if it's 3 different items? |
Thread Tools | |
Display Modes | |
leaking fuel line supply chassis to rail...HELP! | Rebuilder | Welcome New PT Cruiser Members | 2 | 22 Jun 2015 09:01 pm |
Fuel line to Fuel rail... | PurpleHazePT | General PT Cruiser Discussions | 0 | 23 Aug 2014 01:43 pm |
Broke that darn fuel supply line today... | BillsCruiser | Tech & Performance Forum | 3 | 27 Jul 2013 07:57 am |
what size is fuel line from firewall to fuel rail | chitownpt | Tech & Performance Forum | 2 | 18 Mar 2013 06:17 pm |
turbo supply line | 4SPEED | General Turbo Discussions | 6 | 01 Mar 2011 05:32 pm |
