Argh! No Fuel No spark
Like Tree2Likes
Old 23 Jun 2015, 03:57 pm
Unhappy Argh! No Fuel No spark
The car is a 2005 base pt with 60k miles, its been sitting 3 years unused. The head wrapped last time it was driven as a hose clamp broke off a radiator hose. I drained the gas from the tank before letting the car sit.
So far I resurfaced the head changed the timing belt put a new headgasket in with every other seal or gasket I could find. I cleaned the old grounds ,made some new grounding straps borrowed a battery from a running car added 3 gallons of fresh gas. All this only to find the motors internals move freely but there is now fuel or spark. Starter works fine, pcm throws a bunch of codes, I am using the grey factory key ( solid on light then beep).
I am hearing a relay that sounds like the one to the fuel pump but the fuel pump won't pump fuel. Spark plug doesn't appear to throw a spark
What am I doing wrong or still have to fix? Is this this a pcm issue?
Also if anyone has access to the fuel system wiring diagram I would really like to see it.
Old 23 Jun 2015, 06:06 pm
Default Re: Argh! No Fuel No spark
Been done before--- coil harness and Cam sensor harness are the same configuration. If you have the switched --- no spark.
Have someone turn the key and listen for the fuel pump ticking...
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 23 Jun 2015, 06:29 pm
Seriously?... Chrysler used the same plug in the same location.... Well it an easy fix at least
The fuel pump is not doing anything, I pulled the line before the regulator any sucked some fuel through to make sure the line was not blocked. Is there any other system or sender that has control over the fuel pump like a safety shut off?
Old 23 Jun 2015, 07:56 pm
Do you have a OBDII Scan Tool so you can post what the codes are? There are too many possibilities to narrow down and give you a good diagnosis until we get the codes.
Is your little security red light staying on on the dash when you are trying to start the engine or does it go off?
Have you checked the little battery in the ignition key?
Old 23 Jun 2015, 08:17 pm
No battery in the key.The ones that do only work the fob not the key recognition.
Old 23 Jun 2015, 11:03 pm
Hope you didn't use human to "suck" fuel, if you choke and swallow gas will quickly enter your lungs and blood stream, swelling the throat so breathing becomes difficult or impossible and scaring the lungs for life if you pull through.
A friend did this years ago and lived to tell, and then I heard of other siphoning stories that would make you never even think of doing it.
73 Charger SE
01 Sebring flip
Old 23 Jun 2015, 11:35 pm
Thanks for the reminder!
Old 24 Jun 2015, 12:07 am
Hanks that fixed most of the codes
Edit This one was because car is jacked up
P0462 - Chrysler
And this one... I am guessing it's the charcoal can maybe( if it has a sensor at least) it most likely didn't like me suctioning fuel from the fuel line. ( this was with a handheld pump not by mouth but thanks for the concern all the same )
P0499 - Generic
Type Powertrain - Auxiliary Emission Controls - ISO/SAE Controlled
Description
Evaporative Emission System Vent Valve Control Circuit High
Can anyone verify these?
Old 24 Jun 2015, 12:11 am
The light goes of when hitting the starter position with the key. I tried this with a non transponder blank key and the light keeps blinking through the process.
Old 24 Jun 2015, 12:38 am
This one is new most likely because the rear of the car is jacked up so I can get to the fuel pump.
P0462 - Chrysler
Description
Fuel Level Sending Unit Volts Too Low Conditions
Cause
Engine running, then the PCM received a message from the Body Control Module that indicated a Fuel Level Sending Unit Circuit Low condition had been detected
P0462 Chrysler - Fuel Level Sensor 1 Circuit Low
Possible causes
Faulty fuel level sensor
Fuel level sensor harness is open or shorted
Fuel level sensor circuit poor electrical connection
P0499 - Generic
Description
P0499 - Evaporative Emission System Vent Valve Control Circuit High
Possible causes
Faulty EVAP Canister Vent Valve
Faulty EVAP Canister Purge valve
Plugged EVAP canister condition
Faulty EVAP Pressure Sensor
EVAP Canister Vent Valve harness is open or shorted
EVAP Canister Vent Valve circuit poor electrical connection
Yes, I just gave it more details.
No Crank no Fuel No spark madoublet863 Tech & Performance Forum 9 28 Oct 2013 09:18 am
2001 PT cruiser, no spark, no fuel..?..?..? ozmr Tech & Performance Forum 9 19 Jun 2010 10:36 pm
Argh!!!!!!!!!!!!!!!%$&#@ careyk General PT Cruiser Discussions 2 11 Sep 2009 08:58 pm
good spark and fuel, but won't fire up! quintas Tech & Performance Forum 3 27 May 2009 06:20 am
