potential corrosion source
Like Tree4Likes
  • 1 Post By Carl48
  • 1 Post By Busted_PT
  • 2 Post By ptprice
Old 24 Jun 2015, 02:10 pm
Default potential corrosion source
Was in the process of installing some fender trim on my 08 PT and in the process happened to look behind the molded plastic mud flaps at the rear of the front wheel wells. Found the cavity behind the flaps loaded with mud, crud, dirt, and leaves. Cleaned it all out so as not to invite rust to form and rot out the rockers from the inside out.
Y'all may want to check yours... easy to access, only 4 screws to remove.
buddyiramae likes this.
Old 24 Jun 2015, 02:17 pm
Default Re: potential corrosion source
Yes that's a good idea that every so often comes up. But it needs to be as it gets forgot about. The sun roof also drains into the rockers as well.
Old 24 Jun 2015, 07:57 pm
ptprice's Avatar
I just put on a new set of OEM splash guards on the rear wells of SOO BIG. I'd sent photos of the guards in a thread to the forum the previous week showing that they came with the bottom edge of the area your referring to already sliced.
The opinions were varied, but the majority thought those slices were intentionally either done in Mexico originally or duplicated on OEM splash guards to prevent any fluid build up in this area. Most who checked their guards out spotted this slice.
I suggest, if yours aren't sliced to do it to prevent the accumulation problem your having. ptprice
Old 26 Jun 2015, 06:40 pm
my Mexican car has the slices and no buildup...yeehaw
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Corrosion On Headrest Posts? Handy_Cruiser Interior Accessories Forum 25 29 Nov 2014 07:21 pm
BATTERY TERMINAL CORROSION soonercruiser General Turbo Discussions 11 12 Sep 2009 10:14 pm
Sub-frame corrosion koolsville General PT Cruiser Discussions 12 12 Aug 2009 06:22 am
pt cruiser rim corrosion Siobhan Wheels, Tires, Suspension 5 16 Nov 2005 09:50 am
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
