I'm not sure what the problem could be...
Like Tree4Likes
  • 3 Post By rob342
  • 1 Post By SusieQ0288
Old 26 Jun 2015, 02:41 pm
Default I'm not sure what the problem could be...
I have a 2002 PT Cruiser Limited Edition. Recently my engine has been shaking a bit, the car has been sluggish at take off and it stalls if it is stationary with the air conditioning on. There have not been any issues with over heating but the check engine light has been on. Ideas?
A friend of mine who is a "mechanic" says the codes read for my head gasket, but I figured I would get some other opinions.
Old 26 Jun 2015, 02:46 pm
LionPT's Avatar
Default Re: I'm not sure what the problem could be...
What are the codes..??
Old 26 Jun 2015, 03:12 pm
I am not sure. I messaged him for the codes, but he has not sent them to me. He volunteered to fix it for me for $450, but before I spend that kind of money I want to make sure it is the right issue. :/
Old 26 Jun 2015, 05:21 pm
there is no head gasket code.
either:
you need a new fan. see if the fan by the radiator kicks on when the AC is on(with the engine cold)
your Idle air control needs to be cleaned or replaced, this is pretty easy. takes about the skill of an oil change
you have too much refrigerant in the AC system
if you or a friend has added refrigerant with a DIY kit i'd vote #3
if you drive like a mope, I'd vote #2
if the fan doesn't come on, I'd vote #1
or you may just need a basic tune up. have you had the plugs/wires/pcv and air filter changed lately?
Old 26 Jun 2015, 08:58 pm
either:
Motor mounts may be worn out if they havent been changed
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 27 Jun 2015, 07:08 am
Joe I think you might have missed the other part of her post.
Originally Posted by SusieQ0288 View Post
the car has been sluggish at take off and it stalls if it is stationary with the air conditioning on. There have not been any issues with over heating but the check engine light has been on. .
Old 27 Jun 2015, 02:07 pm
I haven't had a tune up yet so maybe I'll try that. I do kind of drive like a mope so that may also be it hahaha
You guys are awesome I'm definitely going to look into these options first before I fork out the money for something expensive.
rob342 likes this.
Old 27 Jun 2015, 02:15 pm
Double post
Old 27 Jun 2015, 02:16 pm
check if the fan comes on with the AC as well. takes under a minute. start the car. open the hood, turn on the AC, make sure the fan by the radiator is spinning.
no reason to do a tune up if the fan is the problem
Old 27 Jun 2015, 02:32 pm
Awesome, will do! Hopefully it is an easy fix
Starter problem? Relay problem or others? postbeauty General PT Cruiser Discussions 3 22 Jun 2015 05:52 pm
2001 PT Auto Trans Problem and Engine Rev Problem johnwwjr Tech & Performance Forum 4 18 Apr 2015 10:00 am
AC problem became Overheating problem BilltheBrewer Tech & Performance Forum 1 23 Jul 2014 11:31 pm
Window problem and AC problem kaypriest Tech & Performance Forum 30 04 Jul 2014 07:42 am
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
