Rear wiper assembly removal
Like Tree2Likes
  • 1 Post By Busted_PT
Old 26 Jun 2015, 06:51 pm
Gkon's Avatar
Default Rear wiper assembly removal
Hi all,
I did a search under various titles, but couldn't find exactly what I was looking for.
My rear wiper assembly is rusty. Also, the grommet is old and torn.
I'd like to remove the assembly so that I can paint it, and so that I can replace the grommet.
Can anyone guide me as to how the wiper assembly is disassembled and removed from the rear window?
Also, is there a specific color for the wiper assembly, or will flat black do the trick?
Thank you.
Old 26 Jun 2015, 07:24 pm
Default Re: Rear wiper assembly removal
Originally Posted by Gkon View Post
Hi all,
Thank you.
You need only to remove the center plastic button . Then remove the nut. Grasp firmly and wiggle side to side to pull off shaft. I would recommend some rustoleum either hi heat or wheel semi gloss black. This will last and look way better than flate black. Will look as new if you get it ready to paint decently.
Gkon likes this.
Old 26 Jun 2015, 07:42 pm
Check this thread: Rear Wiper Grommet? I just uploaded some pics and whatnot from replacing my grommet.
When you re-install the wiper arm don't go too crazy on the retaining nut. The torque spec is 160 to 175 in. lb. (13 to 14 ft. lb.). That's firm, but not crazy tight. You wouldn't want to break the shaft on the wiper motor.
Old 26 Jun 2015, 08:05 pm
Gkon's Avatar
Thanks very much!
I happen to have some hi heat rustoleum, so that's what I'll use.
While I'm at it I'll remove the rear hatch panel to take out the wiper motor and replace the grommet for the wiper arm. Mine is old and cracked.
Old 26 Jun 2015, 08:29 pm
Thanks very much!
Good luck with your repairs.
Gkon likes this.
Old 26 Jun 2015, 08:46 pm
Gkon's Avatar
Thank you, I'm looking forward to them.
Now I have to figure out how exactly to pop out the liftgate trip to remove the rear wiper motor, so that I can replace the grommet.
Old 27 Jul 2015, 12:50 pm
Gkon's Avatar
So, I got around to doing the grommet replacement and rear wiper arm painting.
Low quality pics, but you'll get the idea. The first is the old, chewed up grommet and rusted arm. The second is the new grommet (seems to be a different style than the original) and the painted rear wiper arm.
For the time being, I used hi heat bbq paint (it was handy)
I like the look. If I decide to change it in the future, it's easy enough to pop off the wiper arm again and repaint.
Thanks to all for their help and advice!
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
rear wiper motor assembly rob342 Classifieds: Want To Buy 21 17 Aug 2015 07:52 pm
Air cleaner assembly removal chuckd1991 General PT Cruiser Discussions 1 06 Feb 2014 06:21 pm
Silver pt hatch with glass and wiper assembly server Classifieds: For Sale/Trade 1 06 May 2012 12:03 pm
rear wiper arm removal Shiniquiet General PT Cruiser Discussions 3 19 Nov 2011 12:40 am
Rear tail light assembly's pnwptowner Classifieds: For Sale/Trade 11 15 Sep 2010 07:52 pm
