did timing belt water pump and head gasket
Like Tree2Likes
  • 1 Post By LionPT
  • 1 Post By ronsautojax
Old 26 Jun 2015, 09:04 pm
Angry did timing belt water pump and head gasket
Now I have no fire. I know the cam and crank sensor send signal to cpu and then cpu grounds the proper coil. But I have two power wire in to the coil?
Old 26 Jun 2015, 09:21 pm
cruserdad1976's Avatar
Default Re: did timing belt water pump and head gasket
check the conections on the sensors they can get turned around
Old 26 Jun 2015, 10:32 pm
We need more information before we can start diagnosing what your problem might be.
What year is your PT Cruiser?
Are you sure your coil connector is not switched with another connector?
Old 27 Jun 2015, 04:37 am
LionPT's Avatar
The cam sensor & coil use the same shape of plug...switch them over.
Handy_Cruiser likes this.
Old 27 Jun 2015, 11:29 am
Anyone can help me to figure out why I would have power on the right and left coil wire? I recall only the center should have power from other posts.2001 pt
Old 27 Jun 2015, 11:40 am
Talking Re: did timing belt water pump and head gasket
Ty lionpt! After two months I can finally get back on the road today. I didn't realize the wires were the same.
Old 27 Jun 2015, 12:17 pm
Good to hear it was just the coil connector switched with the cam sensor connector.
head gasket or water pump? chriskoch Feedback and Support 18 29 Jun 2014 06:16 pm
Head gasket failure related to timing belt & Water pump repair? mindful Tech & Performance Forum 15 17 Aug 2013 04:26 am
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? 06turbolite Tech & Performance Forum 8 14 May 2013 09:16 am
Daves Log - 2002 Head Gasket/Timing Belt/Water Pump DigitaL101 Tech & Performance Forum 28 09 May 2013 02:04 am
Head gasket and water pump sixfeetunder Tech & Performance Forum 4 17 Mar 2012 04:02 pm
