Front End Noise
Old 01 Jul 2015, 08:28 pm
Default Front End Noise
I have a 2009 base model (5 speed) with 30,000 miles. I started hearing an unusual noise about 2 weeks ago and I had it inspected and it turned out that the right side bearing was bad. I had it replaced. After driving the car about 10 miles (after the bearing was replaced) I heard another noise. I took it back to the place that did the bearing job and they checked the bearing and the brake and determined that both were ok. They said that the noise is coming from the transmission area. Any ideas what this noise may be and why the bearing would go out after 30,000 miles? Thanks.
Old 19 Jul 2015, 03:24 pm
Default Re: Front End Noise
What kind of noise are you hearing? Mine has just started a noise recently I have took it to three shops and no one has found anything wrong with it. I myself haven't found anything either.
Old 19 Jul 2015, 06:53 pm
Is it a whining sound?
Are you hearing this noise only when you are accelerating from a stop sign?
Does it seem like the noise is less after you drive it for a while?
Help with front end noise... Tobymelodeon Wheels, Tires, Suspension 11 08 Mar 2014 11:43 am
Odd Front end noise. pluminator Wheels, Tires, Suspension 3 12 Dec 2012 03:30 pm
Front end noise nevalicous Wheels, Tires, Suspension 2 29 Apr 2012 03:30 pm
front end noise Luvour04ptgt Wheels, Tires, Suspension 2 29 Sep 2010 07:45 pm
?? Noise From The Front :( hicomp Wheels, Tires, Suspension 7 17 Oct 2008 02:36 pm
