Transmission neutral key off
Old 03 Jul 2015, 08:19 pm
Default Transmission neutral key off
03 PT A/T non turbo car will go in neutral with key out and engine off is that normal ? What would causes that?
Old 04 Jul 2015, 06:39 pm
Default Re: Transmission neutral key off
Is the button on top of the gear shift knob stuck in or can you still push it in and it pops out?
Your PT Cruiser uses a shift-interlock system to prevent you from moving the shifter when it may be unsafe to do so, such as shifting with the ignition off, or when shifting out of Park without pressing and holding the brake pedal first.
Old 04 Jul 2015, 07:02 pm
Where was the transmission when you turned the car off in the first place? You shouldn't have been able to remove the key or turn the engine off if it was in gear.
Old 05 Jul 2015, 03:38 am
[QUOTE=ptcruisersteve;575501]Is the button on top of the gear shift knob stuck in or can you still push it in and it pops out?
I can still push it in and it pops out. It does that with or with out the key. It is my grandmas car and some times she for gets to put it in park. lucky it has not roll down the drive way
Old 05 Jul 2015, 03:49 am
It was in gear. You don't even have to push the brake down to put it in gear. When you drive down the road it keeps making the ding sound if you got a door open and on the dash it pops ups and say door then goes away for a minute then does it again don't know if that is relayed ?
Old 05 Jul 2015, 11:44 am
I would suggest you check the shift position switch and the stop light switch. The shift lock system controls the operation of the key lock solenoid based on the signal from the shift position and stop light switch.
Old 06 Jul 2015, 12:11 am
Is the shift position switch and the stop light switch located in the steering column ?
Old 07 Jul 2015, 12:34 am
This video below shows where the stop light switch is.
Old 07 Jul 2015, 01:08 am
Stop light switch- brake light switch is the little white switch with the black plunger that is activated by the brake pedal. If you remove it (DON't) it is a one time adjustable then throw it away.
If your brake lights are working don't take it off.
If your brake lights are not work check bulbs and sockets then voltage to lights.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 07 Jul 2015, 08:52 am
On the stop light switch I would suggest checking it with an ohm meter without removing it as JoeX had posted above that it is not adjustable after the first time its installed.
Neutral Safety Switch??? Moto Tech & Performance Forum 3 21 May 2013 09:06 pm
pt stalling out..except when in neutral? mykearamirez Tech & Performance Forum 7 15 Jun 2012 08:15 pm
starting in neutral OurPTGT General PT Cruiser Discussions 2 16 Sep 2004 11:07 pm
Coasting in Neutral...BAD? crazie.eddie General PT Cruiser Discussions 10 10 Sep 2004 03:30 pm
Slipping to neutral gear Mojito General Turbo Discussions 7 12 Jul 2004 04:59 pm
