2001 overheating problems
Old 04 Jul 2015, 04:27 pm
Default 2001 overheating problems
Ok just got the car in. Its a 2.4 with auto trans 108K on the clock one owner elderly lady 's car. She has passed away and the car sat about six months to a year prior to me getting the car. Car starts and idles goes up to normal temp until you start driving then it overheats.
We have checked the fluid level and added as necessary, There is no coolant loss out exhaust or into the oil. I do not see a leak on the block yet.
All fuses appear good and we have removed and replaced relays for the fan
We have found that the fan does not kick on. We can jump out the fan to get it to cool down but that is just a band aid solution to it.
Years back I had a caravan that had a similar issue and there was a sensor on the block that would sense temperature and turn on the fan ( 89 4 cyl model) does the PT have a similar kind of thing and if so where? Is there a part of the wiring harness known for corrosion where I may be able to bypass a connector or a ground that may be causing this condition?
Old 04 Jul 2015, 05:16 pm
Default Re: 2001 overheating problems
Before I start with the suggestions I would recommend that anytime you have a problem and you start replacing parts please put the original part back if it doesn't solve the problem. If you don't you may not know if the new part is good or bad. When you do this you are making the diagnosis harder to complete.
I would start with making sure the radiator fan circuit is good. Remove the low speed radiator fan relay and then start the engine. See if the radiator fan starts up automatically.
When you were jumping the fan did you jump both the low and high speeds on the radiator fan to see if both works?
When the engine is cold and you turn on the A/C does the radiator fan come on?
The PT Cruiser has the ECT that senses the temperature and communicates with the PCM and its mounted close to the thermostat. I would recommend making sure the radiator fan circuit is okay first before checking the ECT.
Old 04 Jul 2015, 07:46 pm
actually in messing with it it appears that we have a high fan situation but when we try to jump out the low fan the thing will click a relay but no fan. Also now we have two codes popping up one is P1490 which is the low speed fan and 1495 some kind of a leak detection pump pressure switch problem the car is also now when we drove it stuck in second gear over 40 it bucks,, I don't know if our messing around fried something or what but im thinking that at least part of the issue is the fan motor
Old 04 Jul 2015, 08:51 pm
I would recommend fixing the engine trouble codes first and then start diagnosing the bucking problem. Fix what the PT Cruiser is telling you to fix and then take it from there.
overheating problems 1AZPT General PT Cruiser Discussions 34 18 Apr 2015 10:22 pm
I've had with this car nothing but problems! Overheating now! AshleyNeedsParts General PT Cruiser Discussions 3 07 Sep 2011 11:16 pm
Overheating and AC problems.. KrisBo Tech & Performance Forum 30 25 May 2011 12:08 am
2001 standard problems (overheating) CruzinCajun Tech & Performance Forum 2 02 May 2011 11:12 am
More AC Problems with overheating 06 touring outfit Tech & Performance Forum 5 23 Feb 2010 07:50 pm
