Rattling aircon pump when not in use?
Old 06 Jul 2015, 03:56 pm
Default Rattling aircon pump when not in use?
hi I have a 2004 2.2 crd, when the aircon is not being used there is a loud rattling noise coming from the pump, when you turn the aircon on it disappears! does anyone know if the pump needs replacing? also it doesn't blow cold with the aircon on thanks
Old 06 Jul 2015, 04:31 pm
Default Re: Rattling aircon pump when not in use?
I'm wondering if what you call the A/C "pump" is the same as we call our compressor? if it is, a rattling noise isn't good. Together with the A/C not blowing cold and you could be looking at a replacement to fix things.
Old 06 Jul 2015, 04:44 pm
I googled it (aircon) and it indeed is the ac pump. If it rattles when not engaged, it could be just the bearing on the front. It can be replaced. But usually the pump doesn't engage if the ac is not cold.
Old 07 Jul 2015, 02:29 pm
thanks guys ill have a look weekend
Rattling Shock ejstith General PT Cruiser Discussions 6 14 Feb 2014 08:56 pm
Aircon problem Jassy General PT Cruiser Discussions 3 28 May 2012 04:00 pm
Aircon high side port? AlexJB General Turbo Discussions 11 23 Jun 2008 09:04 am
Rear end rattling Rymanrph Sound and Security Forum 11 13 Jan 2006 01:43 pm
Rattling rear! xyster Sound and Security Forum 5 15 Sep 2005 11:57 pm
