2005 Auto 2.4L Stuck in 1st Gear
  • 1 Post By SuzaMan
Old 08 Jul 2015, 10:28 am
Default 2005 Auto 2.4L Stuck in 1st Gear
I have a 2005 2.4L Auto with almost 300k. The transmission when in drive will not shift up into 2nd gear. It will not shift into 3rd gear when trying to do so manually. It just stays in 1st gear. Reverse works fine. Recent history....All was fine until I had a collision. The front end was damaged in the accident. The front shroud had to be removed. This is when the problem started. Also the speedometer also quit working at the same time. There are no other major issues at this time. Transaxle fluid level is good. The shift cable was recently replaced. What do ya'll think?
Old 08 Jul 2015, 06:14 pm
Default Re: 2005 Auto 2.4L Stuck in 1st Gear
Speed sensor or wire may be damaged on the speedo. I Would remove the air box and battery if needed. Then disconnect the shift cable. See if the shifter will work freely. Then manually shift the trans leaver. One of these will have an issue. You will want to set the emergency brake before doing this.
Old 09 Jul 2015, 09:24 pm
Ok. So I Remove the Air Cleaner, Battery and Battery Tray and found that the TCM output sensor (Speed Sensor) to be damaged by the collision. Tomorrow I will replace the sensor. Hopefully this will fix the issue. Thanx
Handy_Cruiser likes this.
Old 13 Jul 2015, 04:24 am
VNT's Avatar
VNT VNT is offline
Lets us know the outcome.
You indicate you have 300K miles on the transmission?
Whats the secret?? What kind of maintenance have you done to it to get
300k miles
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 15 Jul 2015, 06:55 pm
2008ptcruzrtouring's Avatar
300k miles
I know I'm not him, but I got 210k on my Sebring (same tranny) and I got by with regularly changing the oil and never using 3rd or "L" but I'm pretty sure a fluid flush and fill every thousand miles would help, too
Proud owner of a stone white 2008 pt cruiser Custom Series with 92,xxx original miles and counting
2001 pt stuck in gear but wont move (5 speed) madmanmike1972 Tech & Performance Forum 7 12 Apr 2014 08:36 am
Transmission stuck in 1st gear 2007 PT Cruiser Touring (Automatic transmission) ProdigyMan Tech & Performance Forum 7 19 Jan 2014 02:51 pm
2005 4 Speed Auto - Won't Go Into Any Gear jmbrads1 Tech & Performance Forum 5 12 Dec 2012 07:39 am
Did Transmission Fluid Change...Now Its Stuck On 1st Gear sirminder Tech & Performance Forum 25 28 Jun 2011 02:42 pm
Auto Gear knob loose. deathchimp Interior Accessories Forum 6 06 Feb 2009 10:59 pm
