NEED HELP lower control arm bolt
Like Tree3Likes
  • 1 Post By walazono
  • 2 Post By Leob1
Old 11 Jul 2015, 12:13 pm
Default NEED HELP lower control arm bolt
I'm trying to replace the lower control arms, and the rear bolt captured nut broke loose. I was able to drill a hole to access it, but how do I hold it to get the bolt out? is it a hex nut, if so what size? Vice grips?
Any help would be greatly appreciated, the bolt is stuck half way out.
Thanks
Old 11 Jul 2015, 12:31 pm
Default Re: NEED HELP lower control arm bolt
I found this video in one of pt cruiser searches, maybe it will help:
David
Old 11 Jul 2015, 03:03 pm
just a friendly note.. if you cut the floor with an angle grinder, take great care to shield the sparks from hitting the upholstry. the sparks will burn any thing with a felt feel, such as a seat, headliner, or visor almost instantly.
Old 11 Jul 2015, 08:50 pm
Thanks
Might try getting someone with a mig welder to tac the flat nut so it doesn't spin anymore.
Then try screwing it back in and put never seize on the threads.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 11 Jul 2015, 10:16 pm
The nut has 2 flats instead of 6 on a hex nut. It's almost an inch wide. In addition to the other comments, I'd suggest stuffing a rag into the frame below the nut (from the top side) to catch your tools that will try to fall down there.
The first trick is to stuff an allen wrench between the nut and the cage, then try to tighten the bolt. This might clear any rust that was caught in the threads. Add WD-40 etc. and work the bolt back and forth until the oil gets in there.
If you haven't already done the other side you may want to drill a small hole in the floor to get the WD-40 straw in there to soak the bolt on that side ahead of time.
JoeX likes this.
Old 12 Jul 2015, 01:53 pm
Success! The allen wrench trick worked like a charm. I tried using a screwdriver to keep the nut from spinning, but no joy. The allen wrench worked out and in. I was able to screw it back in a bit, clean it with a small wire brush(after a trip to Lowes to get one), more PB, and was then able to back it out. Getting the arms out and in was a pain!
Walazono, if your ever in NJ, give me a shout, I owe you a burger and some beer!
Thanks!!
rcktpwrd and JoeX like this.
Lower motor mount bolt sheered off invidious Tech & Performance Forum 6 16 Sep 2013 05:08 pm
Lower control arm rear bolt Ramrod66 Wheels, Tires, Suspension 0 25 Nov 2012 01:53 pm
Lower motor mount bolt specs (missing bolts) joe504 Tech & Performance Forum 2 17 Sep 2011 05:28 pm
Lower control arm bolt LNBNDN Wheels, Tires, Suspension 3 03 Jul 2011 05:51 pm
Lower control Arm Bushings BOLT Madturtle Tech & Performance Forum 3 10 Jun 2009 02:00 pm
