Ground wires on the front struts
Old 18 Jul 2015, 01:10 pm
commosutra's Avatar
Default Ground wires on the front struts
I replaced the front struts and rear shocks on my 2001 LE.
While pulling the old struts of the front I noticed there was ground clamps that was held on by bolts but no wires coming off the clips. Are these suppose to go to something? and Is this the reason my ABS light / TRAC are are not working properly?
Old 18 Jul 2015, 02:25 pm
Default Re: Ground wires on the front struts
Follow the link below and it shoud answer all your questions.
ground wires from body to front struts?
Old 18 Jul 2015, 05:27 pm
commosutra's Avatar
I was looking over the notes from 2010, when I seen the response, Ill pick you some industrial grade ground straps and install them. Thanks for the quick response!
ground wires from body to front struts? jacarc1 General Turbo Discussions 16 09 Aug 2014 12:34 am
Front Ground Straps to struts, WHY? CREWZIN Wheels, Tires, Suspension 0 23 Mar 2011 03:02 pm
ground wires sbsfan Tech & Performance Forum 4 16 Mar 2011 03:30 pm
Ground Wires? psychejim6077 Tech & Performance Forum 10 10 Jan 2011 10:04 am
ground wire on ft.struts weldone General PT Cruiser Discussions 4 18 Nov 2010 10:01 pm
