03 PT Cruiser with noise coming from transaxle
Old 22 Jul 2015, 02:00 pm
Post 03 PT Cruiser with noise coming from transaxle
Hello,
I have a 2003 PT Cruiser limited with 103K miles. Automatic, non-turbo
Last week noise started coming from the engine compartment when the rpms goes above approx 3000.
I took it to a independent shop I use in the past, and they inform me the the Transaxle is bad, and it cost $ 3000.00 to fit it.
The car does shift correctly, but sometimes is down shifts hard (load click)
Any ideals on what the problem may be?
Old 22 Jul 2015, 02:05 pm
chigger_ns's Avatar
Default Re: 03 PT Cruiser with noise coming from transaxle
Check the motor mounts.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 22 Jul 2015, 02:15 pm
post a video. it will help prevent you from checking 85 different things people will recommend that you try.
you might also have it scanned for codes. for example, if i unhook the temperature sender from our 99 malibu it shifts hard like a racecar.
I hear a noise coming from a houstondriver Tech & Performance Forum 9 26 May 2015 07:46 pm
Grinding noise coming from my 2005 PT Cruiser PTClueless Tech & Performance Forum 9 03 Feb 2014 10:46 am
Odd noise coming from right hand wheels... Moowoman Wheels, Tires, Suspension 2 30 May 2012 01:58 pm
Grinding/rotating noise coming from left side of car when coming to a stop...help? quietcharm23 Wheels, Tires, Suspension 3 10 Apr 2011 08:43 pm
whining noise coming from car? feefeethaflee Tech & Performance Forum 14 14 Feb 2010 10:50 pm
