P0301 code problems. Please help
Old 22 Jul 2015, 04:10 pm
Default P0301 code problems. Please help
Good Day,
I ran a scan when I saw the check engine light appear on my vehicle and the code P0301 came up. The car only has 49223 miles. What would you recommend be done to solve this issue.
Also I ran the scanner and recorded the freeze frames but I dont know what the information is say. Can someone interpret it for me?
Old 22 Jul 2015, 04:17 pm
Default Re: P0301 code problems. Please help
Use your scan tool to clear the codes and see if your DTC mis-fire returns.
If so then you need to check Ignition wire, Spark Plug, then maybe a compression check, ....maybe.
If your PT is not exhibiting a rough idle and associated misfire sound out the tail pipe chances are the DTC will self clear.
The data shows mostly an engine off key ignition on. Maybe an idle log as well.
Old 22 Jul 2015, 04:20 pm
ops cell phone is double posting again..
P0301 Code, Again rckstein Tech & Performance Forum 18 06 Dec 2014 06:40 pm
P0301 code - was IAC valve Wingerbill Tech & Performance Forum 4 14 May 2012 09:54 pm
got a p0301 error code...help bkh67 Tech & Performance Forum 1 20 Jan 2011 06:34 pm
P0301 Code even with new plugs and wires? ottoman Tech & Performance Forum 3 10 Feb 2009 09:07 am
error code P0301 chicagocruiser Tech & Performance Forum 4 28 Dec 2008 06:06 pm
