Here's the latest timing belt question...
Old 24 Jul 2015, 11:32 am
Default Here's the latest timing belt question...
So, looking for advice on when to change my timing belt.
Just got my second PT, this one is an 04 GT with only 52k.
It was grandpa's car, and he only drove it about 500 miles in the past two years. Meticulously maintained (former long haul trucker who did most of the maintenance himself).
He has NOT done the timing belt and water pump though.
And, he had it in Sonoma, CA (wine country), where it is hot and dusty.
So, the question is: can I check the condition of the timing belt cheaply?
I am *pretty sure* you all will tell me to bite the bullet and change these things now, with no delay. But, it would be good to at least know the condition first.
And, this is not a repair I feel comfortable doing on my own.
Thanks for your guidance!
Old 24 Jul 2015, 11:46 am
Default Re: Here's the latest timing belt question...
If it were mine, I'd change the timing belt at around 80,000, just due to it's age and lack of use. The belt could look like it's in really good shape and still break.
Expect to shell out between $800 and $1200 to have it replaced along with the tensioners and water pump.
2016 Kia Soul Plus Black
Old 24 Jul 2015, 02:09 pm
I don't drive that much, so 80k might be 6 years from now (or longer). Good to hear you say 80k, I haven't seen anyone talk about timing belt problems from age - only mileage. But there seems to be a lot of talk about the *potential* for age to wear the timing belt early.
Old 24 Jul 2015, 02:47 pm
'Bite the Bullet" is my vote, its already 10+ years old, 5 years past what I've read as serviceable. If you are a gambler, have it your way.
Sometimes with age the cogs (teeth on the belt) strip off and same result and it will happen at the most in opportune time.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 24 Jul 2015, 03:45 pm
First you can't tell by looking with that mileage. Well you can by bending the belt back on itself to see if it cracks. you have to have it off to do that. There are several that I have read over the 4 or so years that had the belt break with low milage. My feeling is, if it was driven on somewhat a regular bases versus sitting for months in between driving. I wouldn't be as worried about the dry rot. i think 7 years is the actual suggested time thing. But I have seen some go way past the milage of 100K. They of course stayed on the road and put the milage on quickly. Maybe you will study up on the procedure on here and do it yourself a couple years down the road.
Old 25 Jul 2015, 04:21 pm
I would guess that most timing belts do not break but rather the teeth strip off and the belt no longer functions. Don't get me wrong though, I have seen many photos of broken belts but I think the broken ones result from teeth stripping and then thelt tearing as the rubber disintegrates and the engine stops. My son's GT belt came out in one piece with about seven teeth missing but looked in great shape otherwise. Thirst at something like 93K.
Old 26 Jul 2015, 10:20 am
ptprice's Avatar
My recent road side experience with timing belt failure and replacement of the belt and components was evidenced as a 5" segment of the belt teeth being stripped or sheared off. In all other respects the belt, from the back side, still looked good. Cher` Che` the teeth.
Replace it sooner rather than later! Don't get stuck with a road side incident. Have it done as predictive maintenance not last minute corrective (extra expense) maintenance! You may not luck out and run into reliable trustworthy, honest people as I did, in a situation like that. Happy PTin' ptprice
Old 26 Jul 2015, 11:57 am
mine snapped cleanly in half, all writing on the belt looked good, and there were no stripped teeth. mine snapped when i pegged the brake going ~25 in 3rd gear without pushing the clutch. drunk leaving a VFW hall pulled out in front of me on a wet street. hit the brake, locked the tires, snapped the belt cleanly. ironically, i was scheduled to change it the following day
Timing Belt Question boonie2 General PT Cruiser Discussions 9 30 Jul 2014 12:07 pm
timing belt question Bonecruiser Tech & Performance Forum 7 29 Dec 2012 12:05 pm
timing belt question rob619 Tech & Performance Forum 3 09 Nov 2012 01:45 am
Timing belt question maddyfan171 General PT Cruiser Discussions 9 19 Aug 2011 11:03 pm
Another Timing Belt Question...(sorry!) sscanlan Tech & Performance Forum 10 17 Nov 2010 11:04 pm
