blowing fuel pump and asd fuse
  • 1 Post By rob342
Old 25 Jul 2015, 02:56 pm
Default blowing fuel pump and asd fuse
I have changed my fuel pump and it keeps blowing the fuse, after changing the pump i started the car let it run, and after a few min of runnig it just died. Any ideas?
Old 25 Jul 2015, 03:28 pm
Default Re: blowing fuel pump and asd fuse
Welcome to the forum.
I would recommend you introduce yourself to the forum and say a few things about your PT Cruiser.
Where did you get the fuel pump and what brand?
Is it still blowing the fuse?
Engine light on?
Rob342 on the next post has some excellent questions and suggestions.
Old 25 Jul 2015, 04:11 pm
did it do this before replacing the fuel pump?
have you recently changed anything besides the fuel pump?
if it did not do this before, most likely cause would be you pinched or damaged a wire and it's intermittently shorting to ground. second most likely would be a bad fuel pump. new doesn't always mean good.
and more importantly, why did you replace the fuel pump?
if you replaced the pump due to the fuse blowing, you should also understand it feeds the PCM, fuel pump, data link connector pin #16, and the ASD relay to power the injectors, O2 sensors, ignition coil, EGR solenoid(01-02 only), and PCM.
also, i would like to know if there's anything special added by you or the previous owner, and also what the voltage is when it is running before digging in farther to verify it isn't overcharging. own/use a multimeter?
Help! My 01 PT keeps blowing Fuse #13 Hugh_Jorgan Tech & Performance Forum 7 09 Jul 2015 10:50 am
BLOWING FUSE 13 hillbilly678 General PT Cruiser Discussions 7 04 Jul 2012 04:45 am
fog lamp fuse blowing smilanatu Tech & Performance Forum 13 19 Jul 2009 11:07 am
pt blowing fuse to shut off engine ? bruinspt Tech & Performance Forum 2 23 Jun 2009 10:32 pm
Fuse Blowing Zoomer General PT Cruiser Discussions 2 19 Jun 2009 11:48 pm
