Should I plug my fog lights back in??? What say you?
Like Tree4Likes
Old 26 Jul 2015, 06:31 pm
Gkon's Avatar
Default Should I plug my fog lights back in??? What say you?
Hi all,
2002, PT Cruiser Limited with automatic transmission
I bought the car about 2 months ago and have been doing various bits of work to get her trustworthy and also looking good.
I've read various posts about the problems with the fog lights having the multi-switch or connector melt/burn/catch fire, so many people have disconnected their fog lights and/or removed the fuse.
My fog lights are not hooked up (the bulbs are in the housings, but the wiring harness is not plugged in for either light). I have not checked to see if the fuse is pulled or not. So it's obvious the previous owner(s) had a problem or wanted to avoid one.
However, I have noticed in the carfax(Sp?) report that the multi-switch WAS replaced a few years back. If I've understood correctly, the new multi-switches that were installed took care of the melting/burning problem? Is this true?
So, being the guy I am, and liking when all the do-dads work as they're supposed to, I ask, do I plug the fog lights back in, or am I asking for trouble?
What say you?
Old 26 Jul 2015, 06:37 pm
LionPT's Avatar
Default Re: Should I plug my fog lights back in??? What say you?
Originally Posted by Gkon View Post
Hi all,
What say you?
If I remember right, the burning/melting of the harness is usually a headlight problem. The fog light problem is bacause of warn contacts in the MFS.
Old 26 Jul 2015, 06:57 pm
Gkon's Avatar
Really? I got a completely different picture from what I've read but, then again, I'm new at this.
Old 26 Jul 2015, 07:28 pm
Gkon's Avatar
I'm now watching a video on multi-switch replacement and more specifically the problem seemed to be that the fog lights stayed on even with the switch in the off position which drained the battery and also caused the multi-switch to smoke/melt.
Old 26 Jul 2015, 07:47 pm
LionPT's Avatar
I can't find the thread, but "rob342" can point you in the right direction.
The harness plug that is the main problem is the one behind the inside fuse box...but we might be talking about different things.
Gkon likes this.
Old 26 Jul 2015, 10:07 pm
i never had fog lights. the C103 grey connector by the fuse box was melted and caused my headlights, taillights, and some other stuff to go out.
i think in this case it might be more in the handy department?
The "Handy" Aluminum Can Mod To Fix Fog Lights.
Old 26 Jul 2015, 10:58 pm
Handy_Cruiser's Avatar
I fixed my multifuction switch in my 2001 Limited. And I'm about to do the same mod in my 2005 GT. Here's a link:
PS: You can also buy a new switch on RockAuto for about $60.
Old 27 Jul 2015, 08:51 am
Vlefaive's Avatar
I found an MFS at rock auto and was glad I did, now all is well... Fog lights add to the joy my friend.. I use them every day..
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 27 Jul 2015, 09:54 am
Gkon's Avatar
Thanks for the input everybody.
I feel, however, that I need to re-iterate something.
I am not looking into if I have to replace the MF switch. According to the carfax report when I bought the car 2 months ago, the MF switch was already replaced by one of the previous owners.
My question is, since the MF switch having already been replaced, I noticed that the wiring harness is still unplugged at the fog lights. Should I plug them back in? It's my understanding that the replacement MF switches were changed to help take care of the problem with the fog lights not turning off, thus melting the switch.
So is it safe to assume that the new MF switch (which is already installed) is the newer model, thus allowing me to plug in and use the fog lights without worry?
I don't want to plug them in and find out the hard way that it will melt again, as I am in a tough financial position and would not be able to install a new MF switch right now.
Thanks!
Old 27 Jul 2015, 10:03 am
Ray_Dockrey's Avatar
The replacement MFS's will also fail. They fail because of the design of the electrical system, The full electrical load of the fog lights goes through the switch.
LionPT likes this.
Smoke Back-Up Lights? anyone used them> Koch Exterior Accessories Forum 99 15 Jan 2014 06:38 pm
Back up lights lowpt Classifieds: Want To Buy 6 18 Aug 2009 08:35 pm
Brighter back-up lights 2fer Tech & Performance Forum 8 22 Mar 2007 10:21 pm
Tail and Back-up Lights bruent Exterior Accessories Forum 16 27 Mar 2005 06:26 pm
All CLEAR back up lights? 1lowufo Exterior Accessories Forum 5 13 Feb 2005 12:39 am
