Engine Light Code P0882
Like Tree2Likes
  • 1 Post By Handy_Cruiser
  • 1 Post By LionPT
Old 27 Jul 2015, 02:08 pm
Default Engine Light Code P0882
Hi, can someone help me with this.
When the engine light came on in my 2006 PT cruiser, i took it to a parts store and they checked out the car and came up with this code. The read out said the following, TCM power input low, ECM has deteced less than 3 volts at the transmission control relay output circuit. 3 probable causes, open or short circuit condition,failed TCM relay, failed transmission solenoid/pressure switch assembly.
I want to trouble shoot this myself, so where can i locate the TCM relay on a 2006 PT cruiser?
Old 27 Jul 2015, 02:20 pm
Handy_Cruiser's Avatar
Default Re: Engine Light Code P0882
It should be in the fuse box under the hood.
But the very first thing I would do is have my battery load tested at a local parts store like Autozone. And if it is good, make sure you have around 14 volts across the battery terminals while the engine is running. This will help assure the alternator is putting out proper voltage.
Over and over again, we see problems like this pop up when overall voltage is low. And a bad battery can cause this. These things are easy to do and cost nothing. So it's a great place to start.
boogeyman likes this.
Old 27 Jul 2015, 07:41 pm
We need more information before we can help you. The 2006 PT Cruiser can be a first generation or second generation. Does your PT Cruiser have a TIPM?
The image below is showing a TIPM.
Bing Images
Old 27 Jul 2015, 08:37 pm
LionPT's Avatar
Huh
Old 28 Jul 2015, 12:34 am
Originally Posted by LionPT View Post
Huh
There is a date of Manufacture on the driver's side door. It will tell you if the PT Cruiser was manufactured in 2005 or 2006.
Old 28 Jul 2015, 07:38 am
LionPT's Avatar
I know that, mine was in Aug 2005, but it is still a G2.
Old 28 Jul 2015, 08:21 am
This is why I ask if it has the TIPM.
I like to verify what the PT Cruiser has before making suggestions.
Old 28 Jul 2015, 08:37 am
LionPT's Avatar
Alright, I still don't follow...but that's ok.
BTW: I do have a TIPM.
trouble code p0882 limp mode eli PT Cruiser Convertible Forum 6 02 Nov 2016 03:20 pm
Check Engine light code help sohc1996 Tech & Performance Forum 8 30 Sep 2012 07:36 pm
Engine Light on P0139 code shutterbug Tech & Performance Forum 6 25 Sep 2011 05:49 pm
Check engine light on - can't get code Pinkbadge Tech & Performance Forum 5 10 Apr 2011 07:01 pm
P0304 code Engine Light On wedge22 Tech & Performance Forum 1 23 Feb 2010 07:02 am
