Coolant not sucked back from reservoir
Old 29 Jul 2015, 11:47 am
Default Coolant not sucked back from reservoir
So the level in the overflow tank rises slowly, and I need to manually pump it out and refill the radiator.
The radiator cap is new, and thermostat is new.
The overflow tank and the hose are checked, no leak.
What else can cause this problem?
Any suggestion is appreciated.
Thanks
Old 29 Jul 2015, 09:23 pm
Default Re: Coolant not sucked back from reservoir
Thanks
This hose typically does not leak in the traditional sense. You will push coolant into the tank but if the end is lose it will suck air back into radiator when cooling off. A pin hole has been known to cause this as well with this hose.
Old 29 Jul 2015, 09:48 pm
Did you drain all the coolant when you put the new thermostat in? If you did then you need to burp the radiator so you will get most of the air out of the coolant system. Was it burped?
Old 30 Jul 2015, 08:23 am
thanks
I will try to replace the hose.
Do you know where can I purchase the hose?
usually the hose and the tank are sold together.
Old 30 Jul 2015, 08:24 am
I burp the system many times.
but the air still find its way into the system
Old 30 Jul 2015, 08:57 am
thanks
Just get the right size hose at the parts store. may need to take hose with you.
Old 31 Jul 2015, 01:59 am
Funny as I have the same question. Problem is, the overflow hose is so tight at the filler neck that I'd have to slit it off, and I've already cut off enough slack in the past as it is... Got the length and outer diameter; it's the inner diameter I need, alas!
Old 31 Jul 2015, 08:27 am
Did you solve this problem?
Old 31 Jul 2015, 01:13 pm
He need the inside diameter of the over flow hose.
Old 02 Aug 2015, 01:47 am
Yeah, to clarify to the OP, my coolant is coming back, but I'm putting in a new radiator and want to replace the related hoses while I'm at it... could possibly be a pinhole in there as Busted PT suggested, and gotta eliminate all the possible factors I can...
GT Turbo coolant recovery reservoir littleblueGT General Turbo Discussions 1 07 Oct 2014 06:23 pm
Coolant Reservoir Cap LionPT Classifieds: Want To Buy 3 11 Jun 2014 04:43 pm
Coolant hose from reservoir Bansheelos Tech & Performance Forum 2 03 Nov 2013 03:48 am
coolant reservoir question kruzin4now Tech & Performance Forum 2 13 Oct 2010 11:05 pm
coolant reservoir question pineapple Tech & Performance Forum 13 19 Aug 2009 07:02 am
