Ac compressor won't engage after changing timing belt
Old 29 Jul 2015, 11:58 pm
Default Ac compressor won't engage after changing timing belt
Ac compressor won't engage after changing timing belt . Can just the relay and it comes on and works but the fan won't . Anyone had This happen ? What fixed it
Old 30 Jul 2015, 12:25 am
Default Re: Ac compressor won't engage after changing timing belt
I would suggest you check the wiring going to the A/C. Some members have forgotten to put the A/C connector back on or had found it broken off after working on the engine.
Was the radiator fan wire connector disconnected when getting ready to work on the timing belt?
Was the A/C line disconnected when jacking up the engine?
Does the compressor cycle for a few seconds when turning on the A/C?
What year is your PT Cruiser and how many miles?
Pt cruiser ac compressor won't engage after changing timing belt Smar1477 Tech & Performance Forum 0 29 Jul 2015 11:52 pm
changing timing belt on turbo mopar1958 General Turbo Discussions 3 19 May 2015 05:53 pm
Changing timing belt. unioncreek Tech & Performance Forum 2 19 Jul 2012 08:41 am
rough idle after changing timing belt on 01 pt EnragedDolph Tech & Performance Forum 2 13 Oct 2010 03:51 pm
