How did you repair/replace Engine to Strut groundstrap?
Old 30 Jul 2015, 11:09 am
Default How did you repair/replace Engine to Strut groundstrap?
Like many others have experienced, the ground strap to the strut on our PT Cruiser has broken close to the point where it attaches the strut, on both struts. I was wondering if you repaired this or just replaced it (OEM is about $12 each side). Or did you buy some generic groundstrap? If so, what was the length and size.
If this was just regular wire, I would just splice and solder a new end piece to it, but since it is this braided ground wire, I'm not sure if it would be a good idea or it if is doable.
Old 30 Jul 2015, 11:17 am
Gkon's Avatar
Default Re: How did you repair/replace Engine to Strut groundstrap?
I need to replace/repair mine, as well. The one on the left side is broken in two. The one on the right is missing the cap that pops in on the under-body and the wire clip for that spot.
I would assume that a large gauge, copper stranded wire would work just fine.
I'd like to hear from the pt experts on this one, though, as I'm new to this car.
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 30 Jul 2015, 11:21 am
Gkon's Avatar
Here's some good reading on the subject:
ground wires from body to front struts?
Ground strap
Should I replace my '05 Turbo Convertible engine? BigJim333 PT Cruiser Convertible Forum 12 24 Apr 2015 07:08 am
Engine repair or replace advice mecheng87 Tech & Performance Forum 7 07 Jan 2013 02:28 pm
Repair or Replace Turbo Engine-Non Turbo? Ikster General Turbo Discussions 17 07 Feb 2012 12:28 pm
$3,000 to replace engine? dmellen07 General PT Cruiser Discussions 5 03 Oct 2011 03:32 pm
Repair or Replace Logo William_F Exterior Accessories Forum 4 15 Oct 2009 07:31 am
