Replacing center bulb for Climate Controls
Old 01 Aug 2015, 10:03 pm
Default Replacing center bulb for Climate Controls
Hey, guys. I bought replacement bulbs for the 3 locations in the Climate Control module of the dash for my 2002 Touring. I've looked for posts on how to get these bulbs out, but haven't found what I'm looking for.
The lamp on the left side is the one that's a real bi@#$, due to the amount of space you have to work with. I think I've figured a way to get that one replaced. The lamp on the right side is pretty straight forward.
However, the one that I'm having issues with is the one in the center. There seems to be a metal bar running along the back of the assembly that won't allow you to remove or install the bulb. Can anyone tell me how to get around this issue without having to completely disassemble the module and remove the cables? I have the main harness connector unplugged, and I can rotate the module around a bit, but the back is coated with this sticky grease, which I assume is to ensure that the cables operate smoothly. It's kind of a mess, but I'm sure that somebody must've figured out the best way to approach this. I'm open to any suggestions that you may have.
Thanks,
Steve
Old 02 Aug 2015, 11:53 am
soonercruiser's Avatar
Cool Re: Replacing center bulb for Climate Controls
THere is no substitute for having it nearly out in your hands.
But, like you, I did not want to disconnect any cables.
I used a right angle needle nose pliar to deliver the bulb and socket to the correct location.
Then, held in place with my "pinkie", and grabbed to twist in from the front.
https://www.google.com/search?q=righ...wsT8e4yDPk0%3D
Frank, aka SOONERCRUISER,
Old 02 Aug 2015, 11:57 am
Default Re: Replacing center bulb for Climate Controls
Thanks, Frank. I'll give that a try. What makes it a real pain is trying to keep all of that damned grease off of your fingers, and ultimately off of the bulb and its contacts. Yet, another fine example of engineers designing something that obviously had no clue on the impact to the repair persons...
Old 02 Aug 2015, 04:03 pm
Because Trump
Old 02 Aug 2015, 07:43 pm
Fantastic info! Thank you SO much. This is exactly what I was looking for!
hissing noise behind climate controls? crazyptguy Tech & Performance Forum 6 03 Sep 2012 01:57 am
replacing rear high center break light bulb arwenbeth General PT Cruiser Discussions 3 17 Apr 2011 05:26 pm
Replacing bulb on map light absinthe1111 Interior Accessories Forum 0 02 Feb 2010 06:07 pm
Replacing 2006 Center Brake Light Bulb(s)? MickRC3 General PT Cruiser Discussions 6 29 Jun 2009 07:51 am
Replacing fog light bulb Puck Exterior Accessories Forum 5 21 Sep 2004 02:27 pm
