09 PT Overheating, stumbles while idle, A/C blows Pressure out of a valve next Rtire
Like Tree3Likes
  • 2 Post By CREWZIN
  • 1 Post By soyomb
Old 03 Aug 2015, 11:57 am
Default 09 PT Overheating, stumbles while idle, A/C blows Pressure out of a valve next Rtire
I have a 09 PT that keeps overheating when I am at idle too long without AC on or when I do have AC on it overheats while at idle only, but is good at higher speeds. When at Idle, with AC on it sometimes sounds like a loud blowing noise of pressure next to the pass. Tire. And if I have the a/c on at idle it sounds like the car stumbles. I replace the thermostat already. How do I go about troubleshooting? What should I check next
Old 03 Aug 2015, 12:37 pm
Default Re: 09 PT Overheating, stumbles while idle, A/C blows Pressure out of a valve next Rt
Check to see if the fan is working on both speeds. One of the most common overheating problems is when the radiator fan isn't working properly.
soyomb and Bishop_usmc like this.
Old 03 Aug 2015, 01:16 pm
ok I don't think it is working on low. if I buy a whole fan assembly will that fix both speeds, or do I need to do something with relays or fuses?
Old 03 Aug 2015, 01:31 pm
Yes, both fan speeds will be new. I would go for a Dorman fan with a lifetime warranty. Should be able to get one under $100 on Rockauto, Amazon, or one of the auto store chains.
Bishop_usmc likes this.
2016 Kia Soul Plus Black
Old 03 Aug 2015, 03:25 pm
Thank Yall so much for the help, troubleshooting is not my strong point.
Old 03 Aug 2015, 09:04 pm
I would suggest checking to make sure the radiator fan low speed is bad before buying a new one. Check the wire harness radiator fan plug. Make sure all contacts and pins are good. Check the low speed on the fan with 12 volts. See if it comes on. Check the radiator fan low speed relay and make sure it working properly.
Tags
a/c, overheating engine, rough idle
A/C reads NO Pressure, blows warm, no fan turning, no compressor kick on flafishergal General PT Cruiser Discussions 9 30 Apr 2014 05:09 pm
A/C blows warm at idle... Travis2k7 Tech & Performance Forum 11 22 Jun 2011 08:24 pm
Where is the A/C low pressure valve? yl003760 General PT Cruiser Discussions 1 29 Dec 2009 07:36 am
Where is the low-pressure valve to charge AC? fusefan Tech & Performance Forum 2 14 Mar 2009 09:59 pm
cruiser shakes and blows hot air in idle jujuethan General PT Cruiser Discussions 6 17 Feb 2009 11:46 pm
