Repair Help
Like Tree2Likes
  • 1 Post By 03TXPTGT
  • 1 Post By nermis
Old 17 Aug 2015, 05:37 am
Default Repair Help
Hi all.I have just got in to a bit of a bad situation and did a bit of damage to the
front end on the passenger side of my 05. Any ideas of how much it will cost to fix the damage. Any help would be great appreciation.
https://gyazo.com/tabs/975299c3eb8d5f3b0561741cb2b363ca
The front passenger headlight/turn signal, the bumper, sensor's, also the rim is warped.
Old 17 Aug 2015, 07:07 am
Default Re: Repair Help
Pictures not tha good. If it's not visible in the pics. I can't see it far as damage. You didn't show the wheel damage. Or this compleat fender damage. Also a shot of it on the ground straight on. Sitting on level ground. Would help with possible frame damage. Does either door hit the fiender when you open? It doesn't look very bad looking at it. But a prefrontal shop will wright it off due to value of the PT versus repair bill.
Old 17 Aug 2015, 07:25 am
03TXPTGT's Avatar
Your first stop needs to be a salvage yard to pick up a bumper cover as well as potentially a horn and a new vacuum box, all which can be had for very reasonable pricing there.
MJKnight likes this.
03TXPTGT
-2003 Chrysler PT Cruiser GT
-Patriot Blue, Bright Silver Metallic rear spoiler, billet grille, 17" chrome wheels, hyperground cable, Spectre short ram CAI
-119,000 miles and counting ...
Old 17 Aug 2015, 10:28 am
Handy_Cruiser's Avatar
Here's the photos cleaned up a little.
+1 on the salvage yard. He can likely get everything that's broken in the photos pretty easily. Of course if the chassis is bent, it's whole different ballgame.
Old 19 Aug 2015, 07:07 pm
Thanks for all the help only a broken bolt and a vac box, as well as i good the body parts from a pick and pull yard. I noticed that the rubber on the lower motor mount is worn out as well. I found a video on how to fix it. is this the part i need? (http://www.amazon.com/DEA-A2949-Fron...dp/B001C9S5S2/) No frame damage but it does need a wheel realignment.
Cashew likes this.
First repair Waylope Tech & Performance Forum 8 08 Oct 2014 03:37 pm
PT repair help RONptPA Welcome New PT Cruiser Members 3 16 Feb 2014 10:55 pm
Top repair musicman8120 PT Cruiser Convertible Forum 8 17 Mar 2011 10:32 am
Repair Pro tinosa General PT Cruiser Discussions 0 30 Jan 2010 02:06 am
tie rod repair love bandit2 General PT Cruiser Discussions 0 06 Feb 2009 03:02 am
