Crusie control does not turn on sometimes
Like Tree22Likes
Old 20 Aug 2015, 10:07 pm
wingman55's Avatar
Question Cruise control does not turn on sometimes
I just bought a 2006 Limited Edition, and I noticed that about 50% of the time, the cruise control will not turn on. It seems quite random. Otherwise it works just fine.
I have read about disconnecting the battery. Is that the best idea?
Old 20 Aug 2015, 10:30 pm
dalandon's Avatar
Default Re: Crusie control does not turn on sometimes
does it display "cruise" above the odometer when you push the button?
2007 Pastel Yellow PT Cruiser Touring Edition Auto 4 speed, 1 of 2473
Airaid SynthaFlow Cold Air Intake 300-198
UltraGauge EM v1.2
Bridgestone Turanza Serenity Plus 195/65r15
AKA "Banana Car"
Old 21 Aug 2015, 07:03 am
wingman55's Avatar
No, only when it's working, then it does. Otherwise nothing happens at all. When the word "cruise" lights up it works just fine.
Old 21 Aug 2015, 07:09 am
Maybe you have a clockspring that needs replacing. IDK
wingman55 likes this.
Old 21 Aug 2015, 08:36 am
ptprice's Avatar
Check the electric plug going into the cruise control unit for proper seating and that the plug lock is set correctly. That's all that was the matter with mine.
Additionally, if you can visually compare the plug on your CC unit with another PT's this'll be a good guide to getting it right! Good luck. Happy PTin' ptprice
Old 21 Aug 2015, 11:03 am
wingman55's Avatar
Default Re: Cruise control does not turn on sometimes
OK, well I have a set of Field Service Manuals on the way. Should be here soon.
When you say the connector on the Cruise Control, do you mean the under hood vacuum servo? Or is there a 'black box' somewhere that has some connectors on it?
I took a look at the vacuum servo, but did not actually remove and re-set the connector. I will give that a try.
Old 21 Aug 2015, 11:05 am
LionPT's Avatar
There is a black box under the passenger side wheel well that has some connections.
Old 21 Aug 2015, 11:51 am
wingman55's Avatar
OK, thanks, I'll check it out.
Old 23 Aug 2015, 09:59 pm
wingman55's Avatar
Question Re: Cruise control does not turn on sometimes
OK, I am not sure what black box you are speaking of under the passenger side wheel well? From what the manual shows the Speed Control is connected to the PCM (on the firewall) and there is a Speed Sensor. (I have not figured out where the Speed Sensor is yet.) There is a connection on the Vacuum Servo (which looks OK - but I have not removed it and re-seated it yet). The only other connection is inside the steering wheel.
Can you be more specific about what you mean? (Sorry, the vehicle is new to me and I am learning.)
Thanks for your help.
Old 23 Aug 2015, 10:28 pm
dalandon's Avatar
The black box is the vacuum accumulator, if its leaking it could cause issues
UltraGauge EM v1.2
AKA "Banana Car"
Front Turn Signal Lights Turn On and Off When Applying Brake? Danny7627 Tech & Performance Forum 12 20 Jan 2014 09:42 pm
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
2001 modified PT Cruiser Best of Show at Crusie the Falls (2x) ocs craigslist 0 10 Apr 2012 07:56 am
Is your traction control off when you turn car on? love bandit2 General PT Cruiser Discussions 8 01 Mar 2007 12:13 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
