Battery Hold Down - Is there a better way?
Like Tree29Likes
Old 22 Aug 2015, 03:34 pm
Gkon's Avatar
Default Battery Hold Down - Is there a better way?
Hiya team (because I do feel like we're all a big team )
My battery sits in its tray, and I have it clamped down with the stock battery hold down Chrysler has provided. This prevents my battery from jumping up when I hit a bump. However, it doesn't prevent my battery from sliding side to side.
In the picture, my battery is pushed all the way to the side of the engine bay, leaving a good 2+ inches of space on the left. The battery doesn't stay put, though. It slides left and right, easily, at least when I push it by hand.
I've seen pictures of a top mounted hold down (I think it was Handy_Cruiser). Was that stock, or aftermarket? I've been thinking of cutting a piece of wood to shim into the gap, but that seems so, well, not sleek.
Any suggestions, tips? Do others have this issue? Am I missing something?
Thanks!
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 22 Aug 2015, 03:50 pm
Default Re: Battery Hold Down - Is there a better way?
If you have all the correct OE battery hold owns and the correct battery then there should be no movement in any direction of the battery.
If you start a thread and don't tell us what year and model PT Cruiser you have it makes it difficult with some things to accurately help or give suggestions.
Just because you are a regular remember now does not mean we all are going to remember your PT info?
3rcruiser likes this.
Old 22 Aug 2015, 03:58 pm
Handy_Cruiser's Avatar
If the battery is the right size, the little wedge with the bolt though it should "pitch" the battery in place and not let it slide side to side. First, make sure the battery is properly seated on the back side against the fixed wedge made into the tray. Then make sure the wedge with the bolt is not upside down. At this point you may need to push the wedge in tight against the battery as you tighten the bolt. With a properly sized battery, this is likely unnecessary. But if the battery is a little smaller than is typical, it may be.
In the end, the wedge should be able to hold the battery just fine. This is what most cars have used for thirty years or more. I'm still not sure why Mr. Chrysler decided to use the wonky battery hold-down on the turbo PT's. If you cannot get the wedge to hold the battery tight, something is likely wrong.
Gkon likes this.
Old 22 Aug 2015, 04:04 pm
Gkon's Avatar
My Year and Model are in my signature line, NitroPT. I put it there thinking it would make it easier than having to type it out every time. I guess not.
The battery was installed by the previous owner. I assumed it was the correct battery but it may not be, as there is much more space in the battery tray? I'll look into it.
Thanks.
red06limited and rob342 like this.
Old 22 Aug 2015, 04:07 pm
Gkon's Avatar
Question, my wedge with the bolt is on the side closest to the steering wheel.
From what you've written, it sounds like there is a fixed wedge on the other side of the tray, opposite the one with the bolt? If this is the case, I believe my battery tray does not have that wedge. I'm going to go check right now.
Thanks.
Old 22 Aug 2015, 04:11 pm
Here's a battery tray I took out of a 2002 PT. You can see the wedge made into the back side. It's not much, but its there and it's necessary to hold the battery in place.
Gkon likes this.
Old 22 Aug 2015, 04:13 pm
Thanks.
well looks like you got two good answers.
You might for future reference go look at parts placement schematics and drawing that are all over the internet.
As for your signature be honest you ever completely read mine. LOL
I don't have time to read everyone's signatures because some are long and colorful.
Old 22 Aug 2015, 04:19 pm
Gkon's Avatar
I have read your signature, as a matter of fact.
Mine is short and simple. Shouldn't be too hard to see it. It's just one sentence.
I've have look at parts placement schematics and drawing that are all over the internet.
I also have the parts catalog saved on my computer. But, isn't the purpose of a forum to ask questions? Perhaps something has been added/modified that I'm not finding all over the internet.
Otherwise, what's the point of a forum like this.
Old 22 Aug 2015, 04:21 pm
Gkon's Avatar
my battery tray looks exactly like that.
Is the wedge you're talking about the area with the series of vertical lines?
Old 22 Aug 2015, 04:39 pm
Yes, the "wedge" that is fixed in the tray is really just a series of "teeth". But it should be holding the backside of the battery the same way the wedge with the bolt holds it on the other side.
Here's a closeup. It doesn't look like much, but this tray worked perfectly in my 2001 Limited and held the battery in place securely.
rcreightonb and Gkon like this.
Help! What Size Bolt Do I Need For Battery Hold Down Clamp??? myjeephatesme Tech & Performance Forum 3 19 Dec 2013 03:37 pm
Will the tranny hold? HighOutputSRT4 General Turbo Discussions 15 11 Feb 2013 08:59 pm
Here's why Pepe's on hold TurboDucky Members PT Project 26 04 May 2012 01:50 pm
Need Battery hold down clamp hyltoto General PT Cruiser Discussions 0 10 Sep 2010 07:12 pm
Removing the battery hold down? deathchimp Tech & Performance Forum 11 07 Apr 2010 07:08 pm
