Help! Power Steering resevoir Cap
Like Tree2Likes
  • 1 Post By ptcruisersteve
Old 23 Aug 2015, 10:08 pm
Question Help! Power Steering resevoir Cap
I opened the hood today and found that my power steering reservoir cap was missing. I have no idea how it feel off.
As I look to get a replacement, I can't determine for sure which is the correct cap for my 2003. I see some listed as fitting 2001 to 2003 and others from 2003-2010. It seems that there are two possible parts for my 2003....how can I know which is correct for my 2003?
Thanks,
Old 23 Aug 2015, 11:01 pm
Default Re: Help! Power Steering resevoir Cap
What date of manufacture do you have on the drivers side door?
Old 23 Aug 2015, 11:04 pm
Its an early 2003 with a manufacture date of 8/02
Old 23 Aug 2015, 11:20 pm
The odds are that the listing as fitting 2001 to 2003 would be the correct one but if you want to verify it you can call the dealer with your VIN number and get the manufacture part number of the Power Steering Reservoir Cap you need.
Old 24 Aug 2015, 07:19 pm
I had no luck with the dealer. They provided a part number for the 2006-2010
Searching the web for Chrysler sites which accepted the VIN yielded no answers
Since I don't have one to compare against, I have no idea which is right.
Old 24 Aug 2015, 07:57 pm
Since you went through the trouble of calling the dealer I search for it and I finally found it. Seems the dealer didn't want to be bothered.
2003 Power Steering Reservoir Cap
Part #05093490AA is for CAP, Power Steering Reservoir EDV type engine.
Part #05066031AA is for CAP, Power Steering Reservoir ECC & EDZ type engine
Link below is for one of the CAP's
CAP. Power Steering Reservoir made by Mopar. #05066031AA
Old 24 Aug 2015, 09:39 pm
I'm not familiar with the three letter codes above, but from what I can tell my non turbo gas 2.4L is an EDZ. In which case the cap is #05066031AA
This is the same number the dealer provided. But a search on this number alone shows 2006-2010
#05066031AA: Chrysler. Power Steering Reservoir Cap
#05066031AA: Power Steering Reservoir Cap
According to your link the #05066031AA fits ever EDZ from 2001-2010
Its all very confusing....Chrysler is confusing.
Old 24 Aug 2015, 09:42 pm
The part numbers I posted came out of the 2003 PT Cruiser Parts Catalog.
Old 24 Aug 2015, 09:51 pm
Sold, I will buy the 05066031AA
Thanks
Power Steering Resevoir Tank bheffner General PT Cruiser Discussions 18 11 Jan 2016 06:40 pm
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Hose from coolant resevoir tank is dissconnected kellijac13 General PT Cruiser Discussions 2 28 May 2012 08:34 am
p/s resevoir fuzzy749 Wheels, Tires, Suspension 4 08 Jan 2012 08:00 pm
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
