2001 pt won't start
Old 23 Aug 2015, 10:32 pm
Default 2001 pt won't start
Hi every one I have a 2001 pt that just stopped working it won't run with the cam sensor pluged in do you have any idea for me to try I'm getting every thing needed to start the car stark and air .the injectors just pulse once when the cam sensor is pluged in also I changed it several time and I'm getting no coads help plz.
Old 23 Aug 2015, 10:56 pm
Default Re: 2001 pt won't start
The 2001 & 2002 PT Cruisers have a common problem of a clip breaking off holding the Camshaft and Crankshaft wire harness from falling on the half shaft under the PT Cruiser rubbing through the wires causing an open circuit or a short to ground. I would suggest checking the wiring from the camshaft and crankshaft sensor to the PCM.
Old 24 Aug 2015, 08:44 am
That sounds like the ticket on this. Check this very throughly. If not obvious to start with.
Old 24 Aug 2015, 09:18 am
MJKnight's Avatar
picture in this link mine didnt give me a code..
2001 pt with p0320 code
2001 won't start Mik Tech & Performance Forum 17 30 Nov 2014 09:05 pm
2001 PT won't start, help ! NigeG Tech & Performance Forum 9 03 Sep 2014 09:15 pm
Hot start issue with 2001 Rlundstrom General PT Cruiser Discussions 1 11 Oct 2010 02:52 pm
2001 pt not start'in bugsy1025 Tech & Performance Forum 2 23 Apr 2008 05:31 pm
My 2001 PT won't start! envision_man Tech & Performance Forum 4 29 Jun 2004 08:30 am
