Seat Belt Chime
Like Tree2Likes
  • 1 Post By LionPT
  • 1 Post By discovering06
Old 24 Aug 2015, 08:56 am
Question Seat Belt Chime
Hi Everyone!
How do I turn on the seat belt chime on a 2006 PT , manual transmission. It just stopped working. It's a safety issue. Does it affect the airbag function?
Thank very much in advance!
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 24 Aug 2015, 09:55 am
LionPT's Avatar
Default Re: Seat Belt Chime
Originally Posted by discovering06 View Post
Hi Everyone!
The easiest and recommended way to silence the chime is to use the seat belts as intended, as a safety device and component of the restraint system.
The Enhanced Seat Belt Reminder System will activate if the driver's or front passenger's seat belt has not been buckled within 60 seconds of starting the vehicle. It will also activate if vehicle speed is greater than 5 mph (8 km/h) to alert the driver or front passenger to buckle their seat belt. (The driver should also instruct all other occupants to buckle their seat belts.)
Once the warning is triggered, the ESBR System will continue to chime and flash the Seat Belt Warning Light for 96 seconds or until the driver's or front passenger's seat belt is buckled. The ESBR System will be reactivated if the driver's or front passenger's seat belt is unbuckled for more than 10 seconds and vehicle speed is greater than 5 mph (8 km/h).
The ESBR System can be enabled or disabled by your authorized dealer or by following these steps:
Note - The following steps must occur within the first 60 seconds of the ignition switch being turned to the ON or START position. DaimlerChrysler does not recommend deactivating the Enhanced Warning System.
1. Turn the ignition switch to the LOCK position and buckle the driver's seat belt.
2. Turn the ignition switch to the ON position and wait for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the ON position, unbuckle and then re-buckle the driver's seat belt at least three times within 10 seconds, ending with the seat belt buckled.
Note - Watch for the Seat Belt Warning Light to turn on while unbuckling and off while re-buckling the seat belt. It may be necessary to retract the seat belt.
4. Turn the ignition switch to the LOCK position. A single chime will sound to signify that you have successfully completed the programming.
The Enhanced Warning System can be reactivated by repeating this procedure.
Note - Although the Enhanced Warning System has been deactivated, the Seat Belt Warning Light will continue to illuminate while the driver's or front passenger's seat belt remains unbuckled.
Gkon likes this.
Old 24 Aug 2015, 10:46 am
Thank you worked like a charm
Gkon likes this.
Seat Belt ? red98gt General PT Cruiser Discussions 4 02 Aug 2015 09:46 am
seat belt chimes edscrz General PT Cruiser Discussions 10 25 Jun 2014 11:46 am
seat belt Extenders Koch Interior Accessories Forum 3 06 Feb 2012 10:50 am
Seat Belt Chime? 1lowufo General PT Cruiser Discussions 14 02 Dec 2010 11:39 am
Seat belt extenders eastmountain General PT Cruiser Discussions 1 15 Sep 2010 03:35 am
