Loss of Brake Boost on 1st startup!
Old 27 Aug 2015, 01:33 am
Exclamation Loss of Brake Boost on 1st startup!
Hi all,
I have a 2001 PT Limited, AT, w/only 82k. Been a great car, owned it with 24k and I have always kept up with maintenance, including brakes. Recently the first time driven the pedal is hard as if no boost but by the next corner boost is back and it stays perfect for the remainder of driving time. Vacuum hoses look fine, check valve? No increase in rpm to indicate leak, any suggestions? It just started doing this about a week ago. My wife drive this mostly which really bothers me the most!
I'm hoping someone can think of something I've over looked.
TIA, Ken
Old 27 Aug 2015, 08:38 am
Default Re: Loss of Brake Boost on 1st startup!
I would suggest checking the rubber plug on the vacuum line next to the brake booster. Its common to start leaking.
Tags
brakes, check valve, no boost
New here and brake fluid loss question ojay Tech & Performance Forum 7 03 Jun 2014 01:10 am
Redline at startup chap79 Tech & Performance Forum 13 12 Mar 2013 10:50 am
brake boost- chk valve image request batta Tech & Performance Forum 3 16 May 2010 05:38 pm
oil smell on startup spod Tech & Performance Forum 1 28 Nov 2007 12:31 pm
oil smell on startup spod General Turbo Discussions 1 28 Nov 2007 07:51 am
