What might this noise be?
Like Tree3Likes
  • 1 Post By chuzz
  • 1 Post By wb2kki
  • 1 Post By ptcruisersteve
Old 28 Aug 2015, 05:20 pm
ew55's Avatar
Default What might this noise be?
Was coming and going mainly in the morning but now seems most of the time.
20150827_115820_zpscl6b4ti4.mp4 Video by tbaker | Photobucket
<2003 Dream Cruiser 2>
Old 28 Aug 2015, 05:28 pm
Default Re: What might this noise be?
justa little WD-40 needed.
Old 28 Aug 2015, 05:37 pm
LionPT's Avatar
Sounds like a belt squeak to me.
Old 28 Aug 2015, 09:26 pm
Was this noise there before you did the brake or front end work?
Old 29 Aug 2015, 07:09 am
ew55's Avatar
Yes. I've had this noise for a few months. Not related to the brakes. I have 2 different noises going on.
1. The video in this post. The engine/belt or whatever it is.
2. Low moaning noise maybe from my right side caliper that I had a issue with. Have another post on that.
Old 29 Aug 2015, 09:37 am
Yep, sounds like a belt or a bearing on one of the tensioner pulleys to me. BUT, I'm not a mechanic.
ew55 likes this.
Old 29 Aug 2015, 09:50 am
you can narrow it down:
spray water on each belt one at a time and see if the noise changes, if so you need a belt.
If not remove the first serpentine belt and see if the noise goes away if so problem is one of the following a/c, power steering. adjuster pulley.
If still there other belt is connected to alternator and crank so check for looseness in alternator. I'm assuming NON turbo.
If you have a turbo someone else will have to give you some ideas.
I hope this helps a bit.
Mike
ew55 likes this.
Old 29 Aug 2015, 12:08 pm
I would suggest on belt noises the first thing that should be done to diagnose the noise is to check the belt tension and alignment.
I don't know if this applies to your year PT Cruiser but its worth checking it out.
The Chrysler dealer mentions that the 2003–2004 PT Cruisers with the 2.4 L engine may encounter a belt squeal or chirping sound. The noise is caused by the power steering pump pulley being pressed too far onto the pump shaft. If the power steering pump pulley is more than 0.016 inch from the end of the pump shaft, the noise condition can exist. The Chrysler dealer recommends that the pulley end be flush with the pump shaft.
3rcruiser likes this.
Old 29 Aug 2015, 12:20 pm
Send a message via Yahoo to partyd
Belt, and bad timing belt pulley.
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
Grinding noise while slowing down, whirring noise while speeding up thedarkcanuck Tech & Performance Forum 5 27 Nov 2011 10:15 am
Noise under car??? mjb457 General PT Cruiser Discussions 5 03 Mar 2009 08:04 pm
Noise (vid) PTC06Peet General PT Cruiser Discussions 7 13 Jan 2009 08:49 am
Road noise / exhaust noise in the car. jackatg450 Tech & Performance Forum 3 21 Jul 2004 10:55 pm
