How to Replace Rocker Panels
Old 30 Aug 2015, 02:12 pm
Default How to Replace Rocker Panels
My 2001 PT was run off the road and the rocker panel on the right side is damaged. How do I remove and replace? I may have found a donor at a salvage yard.
Old 31 Aug 2015, 03:29 am
Default Re: How to Replace Rocker Panels
You are probably better off buying a replacement rocker from somebody like Sherman than trying to cut one out at a JY that may be rusted inside. This is a project for someone who is handy with a welder and good at body work. If that's you, go for it.
Old 31 Aug 2015, 05:58 am
Replacement rockers don't fit or are shooed like ours. Do I don't recommend you go that way. But the rest of this post is something to consider.
Old 31 Aug 2015, 09:22 am
I'm in the process of repairing mine for rust just cut about 3 feet on each side. most of it is hidden on the bottom so it don't have to be pretty.
I spot welded on one side and doing the other side today and going to use rivets and spot welds so I can put more seam sealer on it. I got new rockers on ebay one side was about $60 and the other $70.
Get new metal and I agree with the others if your replacing the whole thing if you don't know what you're doing don't. It will not come out nice. If you're playing then take a shot.
Mine looks like crap but since it is moslty on the bottom no one can tell. Give me a couple of extra years I hope.
Mike
Old 31 Aug 2015, 12:23 pm
Since my rocker panel is bent in and up worst at the rear of the front door, will the Sherman attach well? Where is the best place to buy them?
Ike
Old 31 Aug 2015, 01:04 pm
ptprice's Avatar
If rust isn't your challenge, but just the dent in your rocker panel and you have access to a welder, you can light weld pulling washers along the damage and lever the dent out. It'll take a while and some doin'. This done, simply snap the washers off by wiggling them with vice grips, grind down the welds and refinish to your satisfaction.
Keep in mind the stepped pattern every few inches on the underside of the rocker panel and try to keep this configuration in your repair. Depending on just how close to the original you want to achieve, it's just a matter of your time and patience. See attached photo of the underside of a 2005PT rocker panel configured correctly. Have fun with the project. Happy PTin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Tags
body, damage, panel, rocker
Lets talk rocker panels. pluminator General PT Cruiser Discussions 21 06 May 2014 06:39 pm
Rocker panels murphy Exterior Accessories Forum 3 19 Dec 2010 11:27 am
Rusted-out rocker panels? BGW Exterior Accessories Forum 3 30 Sep 2009 12:01 pm
fixing Rocker panels majorstash General PT Cruiser Discussions 7 16 Aug 2009 08:26 pm
Mopar Rocker panels PT4U2C Exterior Accessories Forum 3 17 Sep 2004 04:19 pm
