Starts and stalls
Like Tree4Likes
  • 1 Post By chuzz
  • 1 Post By wb2kki
  • 1 Post By ptcruisersteve
  • 1 Post By whiteclaw
Old 05 Sep 2015, 03:23 pm
JHCruiser's Avatar
Default Starts and stalls
So my wife just told me this morning when her car failed to start that its been doing this for weeks. Lol. That would have been good to know weeks ago.
The car starts alright but stalls right away. I can get it to run by messing with the throttle. It a bit rough but smooths out after a few minutes. Something choke related I think. Maybe ignition. I don't know much about fuel injection, but I'm a quick learner.
Any help would be appreciated
2001 PT Cruiser 4 door Coupe
Old 05 Sep 2015, 09:20 pm
Default Re: Starts and stalls
When's the last time it had a frigging tune up? I'd start with cleaning the throttle body and taking a good look at the air filter, PCV valve and hose and then the spark plugs. It MIGHT just be something that simple.
JHCruiser likes this.
Hey, hey I wanna be a rock star.
Old 06 Sep 2015, 09:14 am
check for vacuum leaks. Look online for checking for vacuum leaks and plenty of suggestions.
Old 06 Sep 2015, 12:20 pm
Is your engine light on? If so what are the diagnostic trouble codes?
If you are not getting any codes I would suggest looking at the wiring harness from the crankshaft sensor to the back of the engine. It has been known that the clip that holds the wire harness breaks when someone is working underneath and pulls it out of the way to work on something else. Check to see if the wire harness is rubbing on the half shaft starting to short the wires to ground.
If the wiring harness looks good I would look at the throttle body. You might need to clean it.
Old 06 Sep 2015, 04:55 pm
whiteclaw's Avatar
Spark plugs I would be looking at. I did at one point have the issue of stalling. I could start it fine and then its like a total cut out. new spark plugs and off we go. Also the cam sensor maybe to look at. I did that too on mine.
Chrysler PT Cruiser 2001, Automatic, No Mods, Right hand drive. 2.0
engin runs rough at operating temp ,starts fine but starts to buck when you give it t moby General PT Cruiser Discussions 1 01 Oct 2014 06:57 pm
Water pump and Timing belt changed, starts and stalls Rascal Tech & Performance Forum 10 17 Sep 2014 09:09 pm
PT Cruiser starts, idles for 2 min, stalls, then will not start enviroPT Tech & Performance Forum 7 14 Jan 2013 12:17 pm
PT starts bad ProDigit General PT Cruiser Discussions 5 03 Nov 2010 02:23 pm
2001 PT - Starts, runs, stalls...won't start silver7 Tech & Performance Forum 12 20 Sep 2010 03:11 pm
