turn signal question
Old 06 Sep 2015, 08:26 am
Default turn signal question
I am new but I have been going through the threads trying to see if i can find an answer before posting.
2007 pt cruiser, the inside dash says turn signals and hazards are working; however, they are not working outside. The turn signals are blinking fast. I have checked the bulds and have bought new , but still did not solve problem. Fuses are not blown but replaced anyway. What do i check next?
Old 06 Sep 2015, 08:41 am
LionPT's Avatar
Default Re: turn signal question
Fast blinking is usually an indicator of a blown bulb, but if that was the case you should have the others working.
Check the sockets, especially the rear.
There are no fuses to check in the G2's 2006-2010...blinkers are controlled by the TIPM.
Old 06 Sep 2015, 11:16 am
I agree with LionPT. Fast blinking is usually a blown bulb. Pull the bulbs and check them first. If they all look good, check the contact points on the bottom of the bulbs and the contact points inside the socket. I've had to remove sockets over the years because the dang spring under them gets rusty and then stuck, not allowing for full contact between the plate and bulb. Sometimes, the spring has been broken, so a new socket's been necessary. Check your grounds on all four sockets too. Maybe you just have a broken or loose, dirty ground wire.
Old 06 Sep 2015, 01:33 pm
If all the grounds and contacts are good I would check the turn signal input and output at the TIPM. This would give you a good idea if the problem is before the TIPM or the TIPM itself.
Old 07 Sep 2015, 09:13 am
The rear sockets burn out and don't make contact you can find them on ebay or dealer for whole lot more. Get a meter or test light and see if you have voltage out of the sockets.
Make sure you have the correct bulb!!!! Some look the same but don't make contact. Been there done that!!
Good luck!
Mike
Front Turn Signal Lights Turn On and Off When Applying Brake? Danny7627 Tech & Performance Forum 12 20 Jan 2014 09:42 pm
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
Turn signal activates signal...and wipers? TF3 General PT Cruiser Discussions 2 19 Feb 2013 12:48 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
