06 Cruiser Erratic gauges /Cluster
Like Tree2Likes
  • 1 Post By rckstein
  • 1 Post By wb2kki
Old 30 Sep 2015, 09:50 am
mystynm's Avatar
Default 06 Cruiser Erratic gauges /Cluster
Hey everyone,
So here I am again after the fun with the timing belt lol BTW the 1st repair shop is giving me a refund for the repair because I was able to prove that they damaged the center bolt and mount by cutting it.
Anyway I changed the PCM out last month because the cluster lights & gauges were bouncing everywhere. That worked for a couple of weeks however it returned so I cleaned the positive cable /negative cable it worked again for about 1 week and the started again.
I took the car into my mechanic on Wednesday, he ran the diagnostics with the engine running I cannot recall the exact code at the moment but he said there is a communication fault between the PCM and Cluster.
I drove the car home but now the turn signals and wipers stopped working. This is really starting to become frustrating to say the least....I know that a lot of owners are having the same issues. I am going to start with the cables because they have never been changed. Oh and also this car belongs to a family member ( I just thought I would mention that )
Something else that confuses me, I called a repair shop regarding the cables and was told 1. They are very expensive 2. They should never need replacement. Is this true? I was also going to change the ignition switch however I don't want to keep putting money into it and not fix the problem.:bang-wall
Old 30 Sep 2015, 10:23 am
Default Re: 06 Cruiser Erratic gauges /Cluster
You might try reseating the connectors on the PCM again. Also check the conections on the cables both ends not just at the battery. Any grounds you find on the body on the drivers side behind the air box. Next the connector on the back of the speedo might need unplugged and reseated. Just some stuff that might help. The plug on the steering column might be chared under the upper cover. Some of that goes through that Circuit.
Old 30 Sep 2015, 10:24 am
rckstein's Avatar
The battery cables, can and do wear out. My PT is on it's third set since I bought it new, almost 10 years ago now. What I have seen happen is that the positive cable end just errodes away (pics below) which then decreases the amount of connection that it has.
But here is what you want for a replacement set:
06 10 Chrysler PT CRUISER2 4L Nonturbo Battery Cable Harness POS NEG Mopar | eBay
bob2006 likes this.
Old 30 Sep 2015, 10:48 am
mystynm's Avatar
Thank you for the suggestions!
The positive cable end does appear to be corroded I will also reset the PCM.
Old 01 Oct 2015, 08:08 am
Sounds more like the TIPM to my untrained eye.
Find something simple not working like the wipers or lights and trouble shoot that. Finding that may fix all the problems. Got to find a good mechanic that is good with electronics.
Had a very weird problem with my Jeep Liberty and it turned out to be corrosion inn a 84 pin connector under the dash.
Good Luck feel your pain. Had a similar problem turn out to be the ign switch.
Mike
JWHF25 likes this.
Blinking indicator lights and erratic gauges - 2006 PT Cruis Convertible ptowner5 Tech & Performance Forum 8 19 Sep 2016 03:37 pm
PT Cruiser cluster electrical issue solved, might help others.. lwprofile Tech & Performance Forum 5 13 Jan 2015 10:14 pm
Instrument cluster flashes and gauges drop mbaker115 Tech & Performance Forum 14 10 Jul 2013 07:33 pm
Aftermarket Gauges for the PT Cruiser PTBruiser1 Vendors & Buyers Forum 4 03 Oct 2010 04:05 pm
instrument cluster problem 2001 cruiser Mike72903 General PT Cruiser Discussions 7 17 Dec 2009 11:56 am
